Final Dyno numbers LE 355
Old Mar 12, 2006 | 03:33 PM
  #31
bunker's Avatar
Re: Final Dyno numbers LE 355
I recommend going true duals even over a mufflex just to try out, I'm certain the numbers will go up regardless of that fact that the mufflex flows a lot , dunno something you could try as I see more power in that setup.
What was your air fuel? I found the best power arond 12.6-12.8 and 32-33* timing, if I ever go back I'll try backing off the timing even more
Old Mar 12, 2006 | 06:34 PM
  #32
blackz97's Avatar
I thought about doing a cutout. Its only a 3.5" mufflex, not the 4". The car is lowered so i really couldnt get away with the true duals, but i think a cutout might fit nicely up in there. A/F Is between 12.3-12.6:1 and timing is i think like 39* in the upper RPM range while down low its retarded a bit to help beat the knock.
Steve
Old Mar 12, 2006 | 06:39 PM
  #33
NightTrain66's Avatar
most have had better luck with 33 to 34 degrees with my stuff. Not sure if you tried this or not but if you get a chance, pull some timing up top and see what it does.
Old Mar 12, 2006 | 07:12 PM
  #34
blackz97's Avatar
Dont quote me on those timing numbers im just going of memory at this point. Ill see if i can get mike to give me a printout of the A/F ratio and the timing stuff.
Steve
Old Mar 13, 2006 | 06:43 AM
  #35
METALBEAST's Avatar
Very nice! Just got my LE cam last week! Hope to get my heads from Lloyd soon
RickRay
Events and Cruise Spots
Apr 23, 2015 02:50 PM
C6LS3
Apr 15, 2015 09:50 AM
ChrisFrez
Dec 7, 2014 06:01 PM
madman69
Aug 18, 2002 03:58 PM
Joe Brodman
Jul 24, 2002 05:24 AM
