Felpro 1406 header gaskets - use RTV or go on dry?
Old Jul 14, 2004 | 04:55 PM
  #16
Scream And Fly's Avatar
Man, no manifold gaskets? How do they seal? That's interesting.
I know my 93 had manifold gaskets though...
Thanks for the replies though - you guys are the best. I love you.
Greg
Old Jul 15, 2004 | 06:57 AM
  #17
MrDude_1's Avatar
Greg
from the factory the cast iron heads were flat... and so were the manifolds.
when bolted together, they sealed fine... until you unbolt them... after you unbolt them theres a chance they cant seal, so you sometimes need a gasket, sometimes you're lucky.
LT1s and most alum headed motors need gaskets because of the diffrent expansion rates of the metal.
btw, thanks WS Sick, i was already late to runn out the door at work lastnight when i loaded this thread, and didnt have time for a better post..
Old Jul 15, 2004 | 07:37 AM
  #18
FastZinTennessee's Avatar
I'm almost sure that my thirdgen 305 TBI had exhaust manifold gaskets on it. If it didn't I'm sure that detail would have stuck out in my head.
Old Jul 15, 2004 | 08:01 AM
  #19
WS Sick's Avatar
Fast Z more than likely they had been removed before and had gaskets put in.
Old Jul 15, 2004 | 08:23 AM
  #20
SAR2K's Avatar
Originally posted by ZDriver96
I stopped using gaskets... I decided to use RTV... much cheaper than buying gasket for everything.seemed to work well on my Heads install.. Cant wait to start it up and see what it runs like. Im sure it'll have a bit more compression with use the RTV instead of the head gasket.
LMAO!!!
As for the gasketless exh manifold on the 3rd gens... very interesting. I can actually belive it as I can see where GM would try to save a few $$$ that way. It can definately work, but the machine work has to be outstanding...
I've worked on marine diesels in the past that used no head gaskets, but these were some pieces with serious flat milling and low RA's.
Steve...
Old Jul 15, 2004 | 08:27 AM
  #21
bo3abd's Avatar
omg.. if u used an RTV instead of a head gasket u will be very sorry soon. the rtv won't hold under pressure even the high temp. one. if i ware u i'd buy a head gasket and istall them before u start the car.
Old Jul 15, 2004 | 08:39 AM
  #22
WS Sick's Avatar
Unless I'm mistaken he was being a smart A....lol
But yeah I'd at least J B weld the heads on over RTV.
Old Jul 15, 2004 | 08:52 AM
  #23
MrDude_1's Avatar
neighbor had a mint 74 triumph spitfire.
he snapped off one of the ears on the exhaust manifold.
agienst my advice, he JBwelded the ear back on. bolted it on.
and as the car warmed up i got to watch JB weld smoke, then kinda ooze off.. like molasses. made a real mess.
he ended up buying a header because it was cheaper... (feels funny to say header instead of headers)
Old Jul 15, 2004 | 08:57 AM
  #24
ZDriver96's Avatar
just trying to keep things interesting
Midnight_Z
Feb 16, 2016 09:36 PM
dylan1303
May 22, 2015 12:24 PM
4586
Apr 29, 2015 01:43 PM
94Z28LS1toLT1
Apr 7, 2015 05:37 AM
rick350
Mar 16, 2015 02:59 PM
