What should I expect for HP with a 230/236 on stock heads?
Car has Pacesetter LT's with true dual exhaust, 4:10's, bolt ons, etc....
I dont want to rev past 6k on the stock bottom end. Where would this cam make its max power on stock heads and how much would it be???
There's nothing wrong with running past 6k rpm on the stock bottom end. Give the LT1 a little more credit than that
I run mine up to ~6250 rpm, and I have been for almost a year w/ no problems whatsoever.
Times in the sig.
Times in the sig.
try this linkie, if it doesn't show them try the next one
http://home.comcast.net/~grygst76/
http://community.webshots.com/user/grygst76
Its a pretty good cam, my buddie dynoed 347/350 RWHP/RWTQ but a hotcam car is faster in an open stretch & at the track because this cam falls on its face at 6kRPM cuz of the XE fast ramp rate.
If you dont want to rev past 6K why are you a doing a cam that big?
You will probably lose low end, have came surge, and then when you start to really make good power your gunna shift it. You need to get a cam that will match your driving style.
Im not trying to be a dick or anything, but that just doesnt make much sense.
