Fastest way to hit 12s without heads and cam
Old Dec 6, 2003 | 01:50 PM
  #16
12SCNDZ's Avatar
'93 Z...3200 stall, 4.10 gears, MSD 7AL-2, Moroso CAI, Splitfire plugs, "Blaster" coil, Taylor 8 MM wires, Hypertech chip, 26x10.5" ET Streets on Weld Draglites...No power adder/full weight/exhaust manifolds...I went 12.82 @ 106 MPH. That was with 93,000 miles on a completely stock LT1.
12's All day long? With that combo, we (3 different drivers) went (12) 12.9 passes, (2) 12.8 passes, (1) 13.1 pass, and (1) "driver error" 13.6 pass at the EFA event at Cecil County last year.
Frank
Old Dec 6, 2003 | 02:13 PM
  #17
lt1camaroman93's Avatar
3600 stall
hooker long tubes
csi water pump
bfg drag radials
lost some weight.
Car went 50 something passes between 12.6 and 12.8 with a best of 12.5. all mph where between 105-107. That was with a stock cam. Then we put the smallest cam we could find out of a tpi engine, the came doesn't even brake into the .500 lift. and the car went 12.3 consistantly. Stock gear still. It can be done easily with bolt ons. good luck to you on your quest.
Old Dec 6, 2003 | 02:24 PM
  #18
Heatmaker's Avatar
Advanced Member
I"m guess A4;s are a but easier at the track with the converters.
Old Dec 6, 2003 | 04:34 PM
  #19
93formula's Avatar
woah woah woah!! smallest cam you could find on a tpi? was this bigger then the stock cam or smaller. would like more info on that. i love it when small cams produce fast runs.
Old Dec 6, 2003 | 04:53 PM
  #20
mebanditws6's Avatar
Re: 12's
Originally posted by Mike383LT1
check out gm high tech they are going to try to do it without touching the valve cover's all bolt on's i think they did it the article is called the grapes of wrath
The Grape of Wrath series was done trying to keep the car 50state legal. So they used shorties and kept all smog equipment, but one thing that boggles me is that they didn't bother tuning the car. Had they went with long tubes, some additional bolt ons, nittos, and even a mail in tune from pcmforless, they would have gotten 12's with alot higher trap speed than the 102 they got after every mod. To me, the money spent on suspension work and 3.42's was a total waste. All they needed was a higher stall converter and the rest engine mods.
Jason
Old Dec 6, 2003 | 05:01 PM
  #21
Robert95z's Avatar
Look at my times... Thats with 2.73 gears and stock stall too
Old Dec 6, 2003 | 06:26 PM
  #22
Mtrhds94Z's Avatar
'Grapes of Wrath' wilted on the vine, as far as I am concerned...
They really didn't finish the project [at least according to the 'survey' post here started by Hunkins months ago before they started the project...]
All the promises by Hunkins left with him I think..
Still a few good articles, tho..
Old Dec 7, 2003 | 12:41 AM
  #23
formula king's Avatar
OOO FORGOT TO SAY ITS A M6
Old Dec 8, 2003 | 12:34 AM
  #24
as soon as i go back to indiana and grab the cam card out of my garage i will post the specs for you. but i do know it is under .500 lift you can barley even hear that it has a cam and the car idles at 650rpm. Stock heads, stock springs, stock rockers...
Old Dec 8, 2003 | 10:07 AM
  #25
93formula's Avatar
thanks
oldschool
Feb 9, 2016 09:21 PM
birdblack
Dec 30, 2014 06:59 PM
Queens94z28
Nov 20, 2014 06:03 PM
NED4SPD
Sep 16, 2002 10:45 PM
