Fastest Le2
Old Mar 27, 2008 | 08:25 PM
  #31
Javier97Z28's Avatar
Moderator
Originally Posted by SS RRR
WAKE UP, SON!
You sleep like that on the line with me ur done!
Oh and answer a PM!
Yah that was a real bad light on my part
If I don't "feel" ready sometimes I just go when I'm good to go on T&T nights
werd on the pm, plz hold.
Old Mar 27, 2008 | 10:46 PM
  #32
kline454's Avatar
Originally Posted by 96LT1TX
Javier, what kind of launches do you do? I am having troubles getting my 60's below the high 1.7 range (11.5" qtps on 15x8 rim could be why). I am just spin then launching launching still
Damn i was low 1.6s front sway bar.
Old Mar 27, 2008 | 11:21 PM
  #33
user 647483's Avatar
Mid/Low 11s should not be a problem with that setup.
I was running 11.8s in a full-weight street car (and 275lbs driver) with a smaller LE1HL cam
N/A on a stock bottom end and 275mm DRs.
With a properly built 383, you'll make more power than I did and be able to rev it high
enough to make use of the meaty part of the curve.
Old Mar 28, 2008 | 08:20 AM
  #34
96LT1TX's Avatar
I got the burnout part down http://www.ssracingphotos.com/galler...9sQn#266409788 just need to relearn the launch part
Old Mar 28, 2008 | 01:19 PM
  #35
street demon2k3's Avatar
Damn, get that 60ft down 96LT1TX! With a 12bolt and a 6-speed Id expect some killer 60fts especially with that raceweight. Should go a lot faster with some better 60's.
Old Apr 7, 2008 | 10:13 AM
  #36
kline454's Avatar
So low 11s is the best we got??
Old Apr 7, 2008 | 06:53 PM
  #37
flyinZ's Avatar
Subscribing
Old Apr 7, 2008 | 08:16 PM
  #38
97s10ondubs's Avatar
On motor...
Old Apr 21, 2008 | 02:45 PM
  #39
mrmint69's Avatar
Been watching this to see if anyone has something to add. TTT
Old Apr 21, 2008 | 03:07 PM
  #40
kline454's Avatar
well first time to the track made 1 motor run went 12.40@108
Old Apr 21, 2008 | 09:04 PM
  #41
96' Formula WS6's Avatar
yea thats a huge stall and thats hurting your trap speed bad, what stall are you going with.
Old Apr 22, 2008 | 07:21 AM
  #42
kline454's Avatar
well i sent that one out to be restalled around 4k.
Old May 29, 2008 | 01:36 PM
  #43
383racecar's Avatar
le2 383 11.56@118.31 and 10.13@135.91 on spray.
Old May 29, 2008 | 04:55 PM
  #44
FASTFATBOY's Avatar
Remember people, vehicle weight has a HUGE effect on how a car runs. Also density altitude.
We seem to overlook these WAY too much.
David
9t4lt4z28
Oct 2, 2015 10:28 AM
Schul365
Aug 25, 2015 05:47 PM
Boss002
Jul 24, 2015 10:47 AM
Boss002
Jul 9, 2015 03:33 PM
95BlackTA
Feb 26, 2003 06:37 PM
