Fastest Le2
Old Mar 27, 2008 | 02:00 PM
  #16
jay_rich's Avatar
My motor was in a 97 T/A (steve40 on boards) And his went 12.08 with LE2 heads, 383 etc.
Now its in my iroc And my iroc is 300 pounds lighter...oh and i plan to hose her with a 150 shot
Jay
Old Mar 27, 2008 | 02:21 PM
  #17
mdacton's Avatar
Originally Posted by dangalla
javier just went 11.26 i think
people like javier are few and far between.....He has a good car, combo etc.
I know javier has been at this stuff for years, maybe its just a knowledge thing and setting it up right.....I don't think his LE2 are any different than the ones going 112 or 114.
We will see what happens this weekend but I think we have a good 112 mph cam only full wt. car with minimal mods.
I trapped way higher 7 years ago with a hotcam only......And to be honest I made alot of mistakes with the install that was costing me 15 h.p. or more between wrong pushrods and incorrect install of the springs.
Old Mar 27, 2008 | 03:15 PM
  #18
CANTONRACER's Avatar
Any combo will take sometime to get used to and you typically have a small number of issues that show up out of no where with new combos.
Mid 11's should be pretty easy to get the first time out with good weather and track prep.
Old Mar 27, 2008 | 03:24 PM
  #19
reamo04's Avatar
IIRC, lloyd is running a 383 LE2 setup and running low 11's.
Javier also has a LE3 cam, cant forget that guys.
Old Mar 27, 2008 | 03:51 PM
  #20
Javier97Z28's Avatar
Moderator
hi.
Diff b/w an LE2 cam and an LE3 cam is minimal.. just fyi, a few degrees on each end.
u went w/ the cc503 right? it can def. do 112 with minimal stuff and full weight. What's the DA like over there right about now..
gl dude, thx for the props.
Old Mar 27, 2008 | 04:55 PM
  #21
96LT1TX's Avatar
Javier, what kind of launches do you do? I am having troubles getting my 60's below the high 1.7 range (11.5" qtps on 15x8 rim could be why). I am just spin then launching launching still
Old Mar 27, 2008 | 05:29 PM
  #22
mdacton's Avatar
Those tires suck, When you get in the box...BURN THE HOUSE DOWN!!!!....smoke em til all you see is smoke. Dump the clutch about 5500.......should do something.
Old Mar 27, 2008 | 05:32 PM
  #23
mdacton's Avatar
We will find out this weekend, its a 503......Hope it didn't mess the car up to bad as far as hooking etc cause we had it perfect.
Not sure on the DA.......but pretty good I would suspect, I'm looking for 12.40's at a min. The headers are really holding it back....
Old Mar 27, 2008 | 05:52 PM
  #24
SS MPSTR's Avatar
yeah....the possibilities include:
1. Leave like a raped ape.
2. Break the rear-end.
3. Pitch sideways.
Old Mar 27, 2008 | 06:16 PM
  #25
street demon2k3's Avatar
12.26@110.8mph with just the LE2.2 cam on stock unported heads. I had problems on every run, Im confident it will go 11's once the tranny shifts on its own. A h/c LT1 like was mentioned should go at least mid to low 11's no problem.
Old Mar 27, 2008 | 07:37 PM
  #26
mdacton's Avatar
Wish for the best, hold the wheel straight and close you eyes......
Old Mar 27, 2008 | 07:46 PM
  #27
dangalla's Avatar
you should add driving instructor to you resume
Old Mar 27, 2008 | 08:02 PM
  #28
Bersaglieri's Avatar
Originally Posted by mad95z
mid to low 12 sec on motor, more on nitro depending on hit
Probably run 9's on nitro.
I've seen a Impala do high 11's with a LE2 kit. Dont see why a much lighter car couldnt run mid to low 11's. Lot's of guys are new at this, just takes time, ask anyone who's been there.
-Dustin-
Old Mar 27, 2008 | 08:11 PM
  #29
Moderator
werd up *********a...
4000 stall automatic, so my rules don't apply
That being said I run a 275/50/15 M/T drag radial on a 15x10 wheel. Still a 26" tire. See burnout:
http://www.zmydust.com/videos/1126_022708.wmv
Old Mar 27, 2008 | 08:17 PM
  #30
SS RRR's Avatar
See burnout:
WAKE UP, SON!
You sleep like that on the line with me ur done!
Oh and answer a PM!
