Fastener Tightening Specifications 1997 LT1
Old Feb 15, 2003 | 10:41 PM
Hyperspeed97z28's Avatar
Exclamation Fastener Tightening Specifications 1997 LT1
For those who didnt know or were curious!
Application
N·m
Lb Ft
Lb In.
Accelerator Control Cable Bracket Bolt
12
106
A/C Compressor Rear Brace-to-Engine Block Bolt
33
24
Battery Cable (at Battery)
15
11
Camshaft Retainer Bolt
12
106
Camshaft Sprocket Bolt
25
18
Catalytic Converter-to-Exhaust Manifold Nut
21
15
Connecting Rod Nut (First Pass)
27
20
Connecting Rod Nut (Final Pass)
55 degrees
Crankshaft Balancer Bolt
85
63
Crankshaft Balancer Hub Bolt
100
74
Crankshaft Bearing Cap Bolt
105
77
Crankshaft Position Sensor Bolt
12
106
Crankshaft Rear Oil Seal Housing Nut and Bolt
15
11
Crankshaft Rear Oil Seal Housing Stud
Cylinder Head Bolts (First Pass in Sequence)
30
22
Cylinder Head Long Bolts (Second Pass in Sequence)
80 degrees
Cylinder Head Medium Bolts (Second Pass in Sequence)
80 degrees
Cylinder Head Short Bolts (Second Pass in Sequence)
67 degrees
Distributor Bolt
12
106
Drive Belt Tensioner Bolt
25
18
EGR Control Valve Relay Nut
25
18
EGR Solenoid Valve Bracket Nut
25
18
EGR Valve Nut
30
22
EGR Valve Pipe Bolt (at Exhaust Manifold)
30
22
EGR Valve Pipe Nut (at Intake Manifold)
25
18
EGR Valve Pipe Stud
12
106
Engine Block Coolant Drain Plug
20
15
Engine Block Oil Gallery Plug
20
15
Engine Bracket Bolt
58
43
Engine Coolant Air Bleed Pipe Bolt
40
30
Engine Coolant Air Bleed Pipe Nut
17
13
Engine Front Cover Bolt
12
106
Engine Mount Through-Bolt Nut
80
59
95
70
Engine Mount-to-Frame or Engine Bolt
50
37
Engine Oil Level Sensor
20
35
Evaporative Emission Canister Purge Valve Bracket Bolt
Exhaust Manifold Stud and Bolt
40
30
Engine Flywheel Bolt
100
74
Engine Flywheel Housing Cover Bolt
8.5
75
Fuel Injection Fuel Rail Bolt
10
89
Fuel Pump Switch and Engine Oil Pressure Gage Sensor
12
105
Generator Bracket Bolt
50
37
Ignition Coil Studs
40
30
Intake Manifold Bolt and Stud (First Pass)
10
89
Intake Manifold Bolt and Stud (Final Pass)
50
37
Knock Sensor
20
15
MAP Sensor Bolt
Oil Filter Adapter Bolt
25
18
Oil Filter
20
15
Oil Level Indicator Tube Bolt
12
106
Oil Pan Corner Bolt Nut or Stud
20
15
Oil Pan Side Rail Bolt or Stud
12
106
Oil Pan Deflector Nut
40
30
Oil Pan Drain Plug
20
15
Oil Pressure Fittings (Plus Necessary Alignment)
12
106
Oil Pressure Gauge Sensor
12
106
Oil Pressure Sensor and Switch
12
106
Oil Pump Bolt-to Rear Crankshaft Bearing Cap
90
66
Oil Pump Cover Bolt
9
80
Oil Pump Driveshaft Bolt
18
13
Oil Temperature Sensor
12
106
Secondary Air Injection Pipe Fitting-to-Exhaust Manifold
55
41
Secondary Air Injection Pump Bracket Bolt
40
30
Spark Plugs
20
15
Starter Motor Bolt
47
35
Throttle Body Bolt
25
18
Transmission Converter Cover Bolts
25
18
Valve Lifter Guide Retainer Bolt
25
18
Valve Rocker Arm Ball Stud
68
50
Valve Rocker Arm Cover Bolts
12
106
Water Pump Bolt and Stud
45
33
Water Pump Driveshaft Bearing Retainer Bolt
12
106
jaimers16
Parts Wanted
Apr 24, 2015 09:43 PM
97z28k&N
Jan 9, 2015 04:58 AM
cmdeshon
Dec 12, 2014 10:51 PM
squarehead
Nov 21, 2014 08:02 PM
