fans not coming on
Old Sep 23, 2011 | 09:52 PM
SmokinZ28lt1's Avatar
Question fans not coming on
Well I just got a 1994 z28 m6 that had some body damage. I got it all fixed and the check engine light was on so i plugged it in and got the 43 esc module code so I put a new knock sensor in cleared the codes and the check engine light went off and it didnt throw any codes..... but after I did that the fans quit working. what could cause them to not kick on? temp sensor? and if so which one? the one on the water pump or the head?
Old Sep 23, 2011 | 10:06 PM
ItsRyan's Avatar
Re: fans not coming on
Water Pump for fans
Drivers side motor for gauge
Old Sep 23, 2011 | 10:38 PM
Fans don't come on until 226 degrees. Have you verified it is reaching that temp?
Info
Old Sep 27, 2011 | 03:24 PM
yea i made sure it was getting warm enough i sat with it running and it got to 240 and they still didnt kick on
Old Sep 27, 2011 | 05:03 PM
Did you verify the temp with a scanner? The PCM does not use the gauge temp to tell the fans to come on.
Magenta_Hearts
Mar 29, 2017 08:54 PM
linz
3rd Gen / L98 Engine Tech
Apr 7, 2015 11:49 AM
Magenta_Hearts
Mar 25, 2015 10:24 AM
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
Red97LT1
9
Dec 17, 2014 06:13 PM
