Camaro wont start. Thought i was crankshaft sensor
Old Sep 24, 2011 | 12:41 PM
ZcamaroZ's Avatar
Engine code po336, changed the crankshaft sensor. Now the car just 'pop, pops when cranking..wont start either. Any help is appreciated. Thanks
Old Sep 24, 2011 | 01:03 PM
raulz28's Avatar
From: 5 minutes from the warzone in mexico(south texas)
Re: Camaro wont start. Thought i was crankshaft sensor
Have you checked the connector for corrosion or anything that can lead to a bad connectiion?
Old Sep 24, 2011 | 01:13 PM
RamAir95TA's Avatar
There is something else at fault here. The CKP cannot cause a no-start condition. The PCM only uses it to detect misfires and nothing else. Many times the CKP is programmed out of the PCM simply because to many people it's more of a nuisance than anything else.
Old Sep 24, 2011 | 01:41 PM
raulz28's Avatar
That is what I thought also then I did a quick google search to verify and it said it can cause a no start condition.
Old Sep 24, 2011 | 01:48 PM
sbs's Avatar
sbs
Nope.
Old Sep 24, 2011 | 02:50 PM
Was that information SPECIFIC to the LT1 engine? In most engines, the cam and or crank position sensors are BOTH required to allow the engine to run. But in the LT1, the cam position sensor (the optical sensor in the Opti) is all that is required.
Old Sep 24, 2011 | 02:59 PM
raulz28's Avatar
Ok I get it now thanks for the quick explanation.
Old Sep 27, 2011 | 06:24 PM
Kevin M's Avatar
Mine does the same damn thing.... I'm gonna change out the optispark unit. Does yours backfire too?
dirtybird81
10
Jan 6, 2015 09:31 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
Jul 4, 2005 05:00 PM
