fans dont turn on anymore....
just finished H+C swap and installed electric water pump
and now the fans wont turn on, the temp keeps on rising and they dont turn on, they used to kick on at 190*
i also removed the A/C too, would that have anything to do with them?
theres only 3 connections that arent plugged in now, 2 on the AC side and one that went to the air pump
everything else is connected!
water pump runs fine
is there something i need to do when removing the AC to get them to work again?
i'm stumped here!
Steve
i'm stumped here!
Steve
check for bad relay's
and also that no wires near the O2 wiring harness's are touching the exhaust manifolds...
on the passengerside harness.... wires directy are involved with the fans somehow.... happened to my friend!!!!
think it has something to do with a ground
You checked fuses right....
Magenta_Hearts
Mar 29, 2017 08:54 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
mspennyhughes
Mar 1, 2015 03:50 PM
Jul 4, 2005 05:00 PM
formula79
26
Aug 5, 2002 12:21 PM
