Fan Wiring
Awhile back I had a 95 v6 camaro and had a hotwire running to a fuse in the compartment under the hood. I just can't remember how I did it but it came on when I put the key in the on position , I think I had it wired to my radio fuse or something
#1, bypassing the relays is a bad idea. Relays are better for high current loads. That's why the factory uses them.
#2, running a power wire to the interior that carries lots of amperage to run the fans runs the risk of fire hazard. If the wire is not fused, it's even worse.
#3, running the fans all the time is wasteful, not only for unneeded wear on the fans but making the alternator create power (hence HP drag) to run them.
#4, fans running all the time can keep the engine too cool, especially in the winter.
I think I could jump the fan relays in the fuse-box. Connect terminals D2 and J2 in the underhood fuse compartment, then run the two wires through a 1-amp fuse. Then attach the same wire to a 2-pole switch, and connect the other terminal on the switch to ground (For OBDI only)
http://shbox.com/1/fan_sw_diagram1.jpg
Sorry, no they won't. Only the RH fan will run on high if you do that. The LH fan won't even come on.
You still have to run a wire and put in a switch. My diagram is no more work than what you said. It's the same thing (and method) you get with an SLP fan switch - only cheaper.
Magenta_Hearts
Mar 29, 2017 08:54 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
Jul 4, 2005 05:00 PM
Rich_z28
Aug 29, 2002 10:44 PM
