Fan Wiring
Old Jun 30, 2009 | 12:16 AM
SmokeyBlaZe's Avatar
Fan Wiring
What would be the easiest way of wiring my fans to come on high when I turn acc on or without cranking?
Old Jun 30, 2009 | 12:47 AM
ak95ta's Avatar
You could buy a SLP manual fan switch if you want easy. Short pin H of connector C100 to ground with a toggle switch if you want cheap.
Old Jun 30, 2009 | 01:05 AM
Awhile back I had a 95 v6 camaro and had a hotwire running to a fuse in the compartment under the hood. I just can't remember how I did it but it came on when I put the key in the on position , I think I had it wired to my radio fuse or something
Old Jun 30, 2009 | 07:43 AM
Bad idea.
Old Jun 30, 2009 | 04:51 PM
Originally Posted by shoebox
Bad idea.
why is that?
Old Jun 30, 2009 | 06:28 PM
why is that?
#1, bypassing the relays is a bad idea. Relays are better for high current loads. That's why the factory uses them.
#2, running a power wire to the interior that carries lots of amperage to run the fans runs the risk of fire hazard. If the wire is not fused, it's even worse.
#3, running the fans all the time is wasteful, not only for unneeded wear on the fans but making the alternator create power (hence HP drag) to run them.
#4, fans running all the time can keep the engine too cool, especially in the winter.
Old Jun 30, 2009 | 07:03 PM
I think I could jump the fan relays in the fuse-box. Connect terminals D2 and J2 in the underhood fuse compartment, then run the two wires through a 1-amp fuse. Then attach the same wire to a 2-pole switch, and connect the other terminal on the switch to ground (For OBDI only)
Old Jun 30, 2009 | 09:37 PM
You can look on my Tech Page for fan switch wiring like it ought to be done. MHO, of course.
http://shbox.com/1/fan_sw_diagram1.jpg
Old Jul 1, 2009 | 02:40 AM
ak95ta's Avatar
Thats a lot of work, it is as simple as I posted above, short pin H of connector C100 to ground with a toggle switch, then the fans will run on high.
Old Jul 1, 2009 | 02:58 AM
Could you explain more please because I have no idea what your talking about.
Old Jul 1, 2009 | 07:30 AM
Sorry, no they won't. Only the RH fan will run on high if you do that. The LH fan won't even come on.
You still have to run a wire and put in a switch. My diagram is no more work than what you said. It's the same thing (and method) you get with an SLP fan switch - only cheaper.
Old Jul 2, 2009 | 05:37 AM
Guest47904's Avatar
Guest
Do it right
http://www.summitracing.com/parts/JET-60602/
Magenta_Hearts
Mar 29, 2017 08:54 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
4586
Dec 31, 2014 02:21 PM
Jul 4, 2005 05:00 PM
Rich_z28
Aug 29, 2002 10:44 PM
