fan and temp sensor?
Old Apr 21, 2005 | 06:29 PM
s i c trans am's Avatar
hey everyone i just bought my self a 94 trans am with 89,000 miles the other day. I've notcied the car will get hot often(not in the red but almost to the line sometimes). Ne ways my intial instinct was maybee this thermostat is ****ed up. So i went and got a 180. it went in fine and helped a little. However i then noticed that my fans were never really going on. Also all the sudden my a/c which was kicking like mad cold, was now making a noise out the compresser like the clutch is slipping on it. any ways i used my friends decoder and the fans went on like they should when u have the ignition and decoder in and found no problems bec the engine lights didnt blink. Then i was tinkering with the car and found sometimes putting on my a/c turned the fans on and would go on and off regulatng the 180 temp like the usual stock. then it would stop after 5-10 minutes. Do you guys thing this could be do to a bad temp sensor in the water pump or is there ne thing else that could cause this, because my fans work but just arent gouing on?
Old Apr 21, 2005 | 10:27 PM
396D1SS's Avatar
Re: fan and temp sensor?
I recommend getting a 160 degree t stat and get tuning from ion to turn your fans on at 160*
Old Apr 21, 2005 | 11:06 PM
Lt1t56's Avatar
When the A/C is not in use the cooling fans dont come on until the engine temperature is 215 degrees
Old Apr 22, 2005 | 12:05 AM
That would be 226°.
I also would not program your fans to come on at 160°. They would never go off.
Old Apr 22, 2005 | 12:12 AM
Welcome to the board.... and PLEASE do not test the language filters.
Which it the stock t'stat.
You can't flash the codes on your 94 using the tools that short the ALDL pins. 1993 was the last year that would work.
Shoebox cleared up the stock fan settings.
Old Apr 22, 2005 | 01:41 PM
kainZ's Avatar
I wouldn't get a 160.. I've seen people's cars run hotter with 160 than 180, because the tstat is always open, and the coolant never gets the chance to really cool down, or so goes their theory.
I also agree with shoebox about the fans.
How is your coolant level?
What is your coolant mixture (parts water : parts ethylene glycol)?
Did you try bleeding the air from the system?
Old Apr 22, 2005 | 02:17 PM
Nah, the 160 thermostat will make it run cooler. Even with the 180°, the thermostat is alway going to be open. That theory is bunk.
Old Apr 22, 2005 | 02:28 PM
kainZ's Avatar
Good to know
Now I have to wonder what was making it run warmer with the 160...
Maybe they had a different water / coolant ratio at the time?
I guess the world will never know..
HectorM52
Jul 30, 2017 11:46 AM
Magenta_Hearts
Mar 29, 2017 08:54 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
