can i use a 94-95 engine harness on a obdI converted 96?
Old Apr 21, 2005 | 07:30 PM
97s10ondubs's Avatar
Im gonna buy a new engine wiring harness for my car for when i pull the motor, some sensors have been put back together with tape and stupid **** like that from the previous owner. I found a painless one that says its for a 94-95 car, didnt see one for a 96-97. Any suggestions?
Old Apr 21, 2005 | 08:46 PM
Firebird355's Avatar
Re: can i use a 94-95 engine harness on a obdI converted 96?
should work just fine... mine 96Z has a 95 computer and 96 harness but the only difference between the harnesses is the Crank sensor plug and the rear o2s i believe
Old Apr 22, 2005 | 01:53 PM
thats what i figured, also good cause i have a double roller and no rear o2's
Old Apr 22, 2005 | 02:01 PM
madwolf's Avatar
Closest to your 96-97 harness would be a 95 harness. The 94, like the 93 has only one engine harness to forward lamp harness connector. Even using a 95 harness you will need to swap a couple wires around in the connectors.
96-97 cars also use a different coil and ignition module, so you will need a coil/ignition module assembly out of a 94-95 car or you will need to fit the 95 harness with 96-97 coil/ignition module connectors.
Old Apr 22, 2005 | 03:33 PM
ok in their catalog it says 94-95, online it says 94-96, that cant be right. http://store.summitracing.com/defaul...=egnsearch.asp
willismoons
Feb 14, 2015 08:42 PM
InfernalVortex
Jan 17, 2015 09:35 AM
Jan 5, 2015 07:14 PM
cmdeshon
Jan 4, 2015 11:15 AM
Jul 4, 2005 05:00 PM
