Fan Fuse keeps blowing..... HELP!
Old Feb 19, 2004 | 11:24 PM
  #16
Originally posted by 95z28 -quicksilver
Now its blowing the fuse as soon as i put it in........ I really dont want to take it anywhere because they are just going to sit around and scratch their heads while they charge me out the *** to fix it....
Good! It should be easier to find, now. Use a meter or test light at the fuse to see the short to ground and then start checking/unplugging all those wires for the things mentioned earlier, until the short goes away. Nice to have a meter with an audible setting so you can hear when the short goes away.
Old Feb 25, 2004 | 05:31 AM
  #17
95z28 -quicksilver's Avatar
From: Austin, TX or Texas State University at San Marcos
Ok well now my fans are WORKING..... The fuse is NOT blown, but the "Reverse Inhibit" system is not working.... therefore i am guessing that it has gone out.... my question now is - What is it? How do i fix it? Probably an question for shoebox.....
Old Feb 25, 2004 | 07:23 AM
  #18
redthunder96's Avatar
The reverse inhibit system should just the the reverse lockout solenoid located by the transmission (next to the skip-shift solenoid)..
I can't help you much because I'm at school in a class but run a search on the reverse lockout solenoid and you should get something.. Or maybe someone else can help you out...
Old Feb 25, 2004 | 07:49 AM
  #19
Anybody have a pic or can be more specific as to where this solenoid is located???
Old Feb 25, 2004 | 08:46 AM
  #20
It's just below the shifter on the LH rear side of the trans. The VSS is below it.
Old Feb 25, 2004 | 10:26 AM
  #21
Can i pull the shifter to get to it or do i have to get to it from underneath the car??? How much is it $$$? And is it easy to replace? Thanks
jerrysims71
Aug 15, 2015 12:47 PM
4586
Aug 2, 2015 01:45 PM
RUNMYTA
Jul 15, 2015 07:50 PM
Jmj93z28
Jul 8, 2015 10:01 PM
Jmj93z28
Jul 8, 2015 06:58 AM
