failed the pushrod test
Old May 24, 2005 | 10:45 AM
97silvermaro's Avatar
failed my first pushrod test at adjusting the RR's correctly.... thought i set them right but about 7 of the pushrods are bent now.... any tips ad tricks i need to know for the new set?
Old May 24, 2005 | 10:58 AM
WS6T3RROR's Avatar
Re: failed the pushrod test
yeah... learn why you bent the 7 that you bent. i dont understand did the rocker jump off the pushrod from being too loose or what. i'm just curious what your valve spring clearance looks like at max lift... and what kind of setup are we talking about here springs rockers cam etc etc.
Old May 24, 2005 | 11:02 AM
NBred94's Avatar
My rockers are in the mail as we speak, I plan on using shoebox's guide LINK
Old May 24, 2005 | 11:03 AM
le2 cam with 1.6 rr... Lloyd matched the springs to the cam... and 7.25 pushrods.... i also tried to crank it when it was out of time... didnt know it was out of time at the time... accidently lined the dots on the crank keyway to the cam instead of the dot on the crank tooth
Old May 24, 2005 | 11:06 AM
oh yeah one of the rockers did jump off.... i couldnt hear any ticking cuz it was open headers so i really couldnt hear anything....
Old May 24, 2005 | 11:07 AM
thoughts keep on comin after i reply... im runnin comp R lifters and RR's
Old May 24, 2005 | 11:12 AM
turbo_Z's Avatar
So you fixed the timing problem right? If the cam was off enough then the valves would hit the pistons which can bend pushrods.. of course bend valves too.
Old May 24, 2005 | 11:18 AM
yea timin is right now
Old May 24, 2005 | 11:29 AM
BUBBA's Avatar
I'd get an adjustable push rod to check the geometry before automatically installing +.050 push rods. JMHO
Old May 24, 2005 | 11:35 AM
should they be adjusted ona a warm motor??? the 7.25's should be right cuz thats what i was told to go with... i know the stock length is 7.20
Old May 24, 2005 | 12:52 PM
BUBBA's Avatar
Hey: If someone told you to go with longer rods, then by all means do it.
CamaroBoy96Z28's Avatar
What you're told to go with and what you need are 2 different things. Lifter height, cam base circle, etc variations determine pushrod length. We all know that for some reason or another what works on one car and another even with the exact same combination can cause slight variation in geometry. To be sure, use a checker to confirm. Its worth it over the potential and very costly damage that can occur.
As far as adjustment goes, I could only get it right with the car running and I found it a lot faster/easier.
Old May 24, 2005 | 01:19 PM
BUBBA's Avatar
You may very well go with the longer rods. I believe with the comp lifters the preset is very close to 0 lash: however, it is my opinion, that whatever you set it at, you should make certain that the RRs maintain contact with the valves unless you want noisey RRs and/or the possiblility of smacking a keeper with a misguided rocker and dropping a valve.
Just make sure that you adjustments aren't too loose, especially if you go with SA RRs. It's probably fortunate that you had non-hardened rods, otherwise you might have done more damage. JMHO
Old May 26, 2005 | 01:16 PM
readjusted the new pushrods yesterday going by Shoebox's 1st method... car cranks up fine... but now it acts like its getting too much fuel? it wont idle but for like 5mins then cuts off and you have to press the accelerator to the floor for it to crank... it didnt act like this with the old pushrods it would crank fine and idle fine... any suggestions... also ive been seein a lot on data logs how do i get a data log on my pcm
sleeperZ96BT
Sep 9, 2015 08:28 AM
realistyc
Jul 28, 2015 07:32 PM
alphaauto
Jul 26, 2015 04:40 PM
Boss002
Jul 24, 2015 10:47 AM
94Form
Jul 17, 2015 10:56 PM
