Failed Emissions...again....
Old Oct 30, 2003 | 08:55 AM
  #31
Mystic95Z's Avatar
Any idea how long you were running that rich? It wouldn't take long to either kill or reduce the cat's effectiveness which could be why your seeing elevated CO & NO.
-Tony
Old Oct 30, 2003 | 12:04 PM
  #32
Chevycobb's Avatar
WELLLLLLLL...did the retest with alcohol....the NO went down and passed! the CO stayed they same....
Old Oct 30, 2003 | 12:16 PM
  #33
Mystic95Z's Avatar
Did you read any of the stuff I linked to above?? If not read
this and goto page 4 which has causes of excessive CO. You obviously have a problem that the alcohol isn't able to mask.
-Tony
Old Oct 30, 2003 | 12:32 PM
  #34
Chevycobb's Avatar
yeah, i did read it...
I found someone who would be willing to sell his cat. and y-pipe pretty cheap. would it be easier install a y-pipe with a cat attached to it, or just the cat.?
Old Oct 30, 2003 | 02:57 PM
  #35
Mystic95Z's Avatar
It might be easier to cut the cat off the y-pipe and weld another on than risk broken manifold bolts. Luckily I didn't need my manifolds because of the headers otherwise I'd have been in a pinch bacause we broke several off trying to get the stock y-pipe off.
Old Oct 30, 2003 | 04:04 PM
  #36
Chevycobb's Avatar
Well i'm thinking my cat pretty much blew itself out at some point before I had the car, so that means it's pretty much gutted, right? and putting on a new cat will quiet it down a little, right? if thats the case then I don't want to lose the sound because I actually like it. If I can get my hands on a cat that I can just put on there and maybe make some sort of fittings for both cats and on the end of the y-pipe so i can just bolt them on and off...think I can do that?? Will a muffler shop be able to do this?
Old Oct 30, 2003 | 04:36 PM
  #37
Mystic95Z's Avatar
Any shop can do it although some wont because of legal reasons. If the insides are blown out a new cat will quiet it down alot. I had a three point flange welded onto my y-pipe so that I can swap my cat with my off road pipe whenever I want and the noise level without the cat on is considerably louder.
Old Oct 30, 2003 | 04:41 PM
  #38
Chevycobb's Avatar
i just have to find a cat that will work...just trying to avoid spending a lot on a small budget
Old Oct 30, 2003 | 04:52 PM
  #39
Mystic95Z's Avatar
Alot of people have good luck with Carsound cat's do a search and see what you come up with. Some can be found on ebay in the 40 dollar range although I dont know what model they are and what size engine they are rated for. I've bought one from www.exhaustproslinc.com before and had good cust service from them and thier prices are pretty good too.
-Tony
Old Oct 30, 2003 | 05:23 PM
  #40
Chevycobb's Avatar
sounds good to me...now how about this?
For some reason muffler shops are charging a lot to put one on around here...can't I just take a torch to it and weld it on myself? actually I would be having fittings welded on for a quick replacement.
Old Oct 30, 2003 | 06:26 PM
  #41
Chevycobb's Avatar
the stock cat is a 3inch inlet/outlet correct??
Old Oct 30, 2003 | 07:48 PM
  #42
Mir Hussain's Avatar
in my 96TA it was 2.5' (stock)
Old Oct 30, 2003 | 08:29 PM
  #43
grendal's Avatar
Should be 2.75" (non-standard size)...
-Michael
Old Oct 30, 2003 | 09:33 PM
  #44
Mystic95Z's Avatar
You wont be able to weld it with a torch. It cost me 65 bux in labor to have my flanges welded on to my y-pipe and high flow cat.
-Tony
Jeff1904
Jun 5, 2016 05:00 PM
damnyankee36
Sep 9, 2015 07:06 PM
Boss002
Jul 24, 2015 10:47 AM
blown383
Mar 1, 2003 10:35 AM
copper88iroc
3rd Gen / L98 Engine Tech
Dec 13, 2002 04:56 PM
