expected problems swapping motor from 95 auto to 97 6speed?
Old Dec 22, 2007 | 11:52 PM
97SS0594's Avatar
swapping motors from my auto 95 Z to my 6 speed 97 SS and problems i should know about?
Old Dec 23, 2007 | 10:08 AM
Need more info.
What PCM will you be using? The obvious issue will be making the 95 engine compatible with the OBD-II PCM in the 97 if that's what you are using (knock sensor, CKP). Will you be switching to OBD-I? Will you have the non-compatilbe OBD-II features programmed out of the 97 PCM? Are you moving the 95 engine WITH the A4 into the 97, or are you mating the 95 engine to the 97 M6 tranny?
cmdeshon
Jan 4, 2015 11:15 AM
Injuneer
Dec 15, 2014 09:36 AM
Lt1son
N2O Tech
Nov 25, 2014 01:52 PM
