Stalling
Old Dec 23, 2007 | 07:41 AM
RichardH's Avatar
Stalling
Hey guys, I have a 1996 z/28 and this only happends when it gets cold. I'll be driving and the car will just die. I notice when it dies the exauhst smells bad, like it has bad gas. I can let it sit for a few min, and it will start. Have been told the opti-spark is probably the problem. Have read in my chilton repair book the because the distributer sits behind the water pump and is a 2 piece unit, its prone to getr water and debrie in it. so I am going to change that. Ran a test on the fuel pump and checks out fine. Has anybody else had this problem?
Old Dec 23, 2007 | 10:11 AM
Have you had it scanned for codes? That would be the logical first step, before dumping money and time into replacing the Opti. And to clarify... when you say "this only happends when it gets cold.".... do you mean it only stalls when the engine/coolant is cold, or when the ambient air temps are cold?
Nayr
Mar 3, 2023 08:34 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
greenzee28
Sep 25, 2015 04:29 PM
SEOJustin
Sep 24, 2015 04:39 PM
damnyankee36
Sep 9, 2015 07:06 PM
