exhaust manifold studs
Old May 28, 2006 | 02:00 PM
JoeliusZ28's Avatar
Question exhaust manifold studs
im in the process of removing my stock manifolds and i guess im not sure how these studs work. on my cousins car the nuts just came off and all the studs stayed in the head. is that what its like on these cars or are the nuts welded to the stud? Obviously they have to come out so im hoping they are welded. I dont have any deep well sockets so i was going to cut the end of the stud off. Bad idea?
thanks in advance, im in the middle of this project as i speak
Old May 28, 2006 | 02:21 PM
Dave89IROC's Avatar
Re: exhaust manifold studs
umm, you mean the BOLTS holding the manifolds to the heads?
they should be bolts, some with a stud piece, you can cut the stud piece off if needed
Old May 28, 2006 | 02:29 PM
Angelis83LT's Avatar
yea. those are all bolts for the stock manifolds.. they have the accessory studs on some of them, if you plan on actually putting studs in then you really shouldn't worry about cutting the stud ends off...
Old May 28, 2006 | 02:54 PM
JoeliusZ28's Avatar
ok thanks thats the confirmation i was looking for. I was 98% sure, but i wanted to be 100% if screwing up means removing the head.
Old May 28, 2006 | 03:13 PM
Javier97Z28's Avatar
Moderator
Don't cut anything off, go get a deep socket....
Old May 28, 2006 | 05:31 PM
JoeliusZ28's Avatar
thats what i ended up doing
got the drivers side out no problem... getting started on the passenger side now.
Old May 28, 2006 | 10:40 PM
...and make it a 6 point, too... (I realize my comment may be a little late )
69z-28
Jan 29, 2016 10:46 PM
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
Chris Anderson
Jan 27, 2015 08:30 AM
spearous
Jan 12, 2015 11:03 AM
