3 Wire A/C pressure switch
Old May 28, 2006 | 06:55 PM
Taylor's Avatar
I am working on a 95 Forumla. The a/c will work if I reset the PCM, I dont have a cable to hook it out to my laptop, working on making one, but no luck. The fans do not turn on when the a/c on. I was wondering what the Ohm readings on the 3 wire pressure switch, I think that it is not working and would like to test it with my meter before replacing.
Taylor
Old May 28, 2006 | 10:46 PM
Re: 3 Wire A/C pressure switch
Lets see... the gray wire is the PCM 5 volt reference and the black is sensor ground. The red/black wire should be the sensor signal to the PCM and I would imagine it would be from ~1-5v depending on pressure.
HectorM52
Jul 30, 2017 11:46 AM
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
Jul 4, 2005 05:00 PM
Ryabut98
Sep 3, 2002 11:45 PM
