Exhaust manifold....cant access back passenger side bolt
Old Apr 29, 2011 | 03:41 PM
prplpepleatr's Avatar
Got a nasty exhaust leak on the passengers side. I believe that maybe the bolts have come loose. The one i could access on the front drivers side was a little loose so im gonna assume that they may all be loose, they have been off since the car does have new head gaskets. So what is my best approach to reach the back bolt on the passengers side? better from the top or bottom, looks like a real PITA, any advice? Thanks.
Old Apr 29, 2011 | 04:02 PM
Bamaboy's Avatar
Re: Exhaust manifold....cant access back passenger side bolt
If it is the same as the 97z28 I just put on some headers and you can get to that bolt pretty easy from the bottom.
Old Apr 29, 2011 | 06:07 PM
Thats what i thought but im not seeing it from the bottom, I can feel it from the top just cant get a rachet on it. I can get the socket on by itsself but cant get the righ angle to fit the rachet in there. Any other suggestions?
Old Apr 29, 2011 | 09:42 PM
Get a flex joint to put between the socket and the ratchet. Use a box wrench.
Old May 7, 2011 | 09:05 AM
richierkoit's Avatar
I have headers, I use a short box wrench to get at mine?
Old May 7, 2011 | 12:16 PM
Bamaboy's Avatar
If you drop your starter you can get a wrench right up in there but you gotta drop the starter to access it easily.
blown94
May 3, 2015 12:48 AM
Jul 4, 2005 05:00 PM
Brett 91 RS LT1
Mar 12, 2003 10:02 PM
Bando
Oct 7, 2002 07:36 PM
blue89iroc
Jul 26, 2002 04:56 PM
