Is this exhaust BIG enough? Big Mama inside
Old Jul 14, 2006 | 12:25 PM
  #31
1racerdude's Avatar
Re: Is this exhaust BIG enough? Big Mama inside
Originally Posted by )2overt SS
Wow, that looks awesome!
Besides a welder... what kind of tools did you need to do that job?
Saw,bench grinder,4" grinder,die grinder and a number of years of experience.
Ya got to have the ability to "visualize" in your mind what ya want it to do/look like and then make it "happen".Also to be prepared to make changes in the middle of the stream without effecting the final outcome.
Ya need to be part mechanic,part designer,pipe fitter,welder,body man,with a good amount of experience.
If ya notice there is "only" one weld joint on each section,'cause a weld mirrors itself on the inside and will disrupt flow if ya can't get to it to grind it smooth.
Old Jul 14, 2006 | 06:30 PM
  #32
1racerdude's Avatar
Originally Posted by T/A lt1
Looks good guys. It will take quite a few tools and some good fab work to do something similar. I brought the all the parts: 3" x-pipe, mufflers, mandrel bends and pipe to a local muffler shop and the guys fab a true dual with x-pipe. I will have to take some pics for you guys. Later Clint
Got pictures???
jasonduaine
Apr 1, 2015 08:09 PM
jasonduaine
Exhaust System
Mar 20, 2015 09:00 AM
carl.froehlich
Mar 13, 2015 12:38 AM
MadMav
Feb 6, 2015 11:02 PM
ChrisFrez
Nov 30, 2014 08:41 AM
