Is this exhaust BIG enough? Big Mama inside
Old Jul 12, 2006 | 10:27 PM
  #16
1racerdude's Avatar
Re: Is this exhaust BIG enough? Big Mama inside
I heated it with a torch and bent it little by little as not to tear that thin metal. It tore anyway and had to weld it all up(fun fun) no easy task on that thin metal. Then we sanded it and fiberglassed the inside to give it some strength and painted it inside and out.
I will get David to post the pictures,but it will be tomorrow as his lights are out.
Old Jul 13, 2006 | 07:19 AM
  #17
chy20k1's Avatar
yeah, it really is a job welding that thin suff... not something to learn on. i know from experience lol
Old Jul 13, 2006 | 10:34 AM
  #18
89TramsAmGTA's Avatar
Very nice. One of the best I have seen. I bet there is no back pressure with that set up.
Old Jul 13, 2006 | 10:59 AM
  #19
LT4POWR's Avatar
Looks good! My exhaust uses that same 2-1 style flowmaster connector.
Old Jul 13, 2006 | 12:11 PM
  #20
96speed's Avatar
Looks like you guys copied my 3 years old seltup .
I'd love to see pics of the inside of the car, because I know mine hung LOW - you must have it tucked way up in there. Don't need a heater anymore, eh?
Ryan
Old Jul 13, 2006 | 02:03 PM
  #21
1racerdude's Avatar
Ryan
Well,not "way" up but the bottom of the pipe is a tad above the bottom of the floor pan.
"Heater-- what heater-- the headers were also modified to fit. They are 1-7/8" Hedman. It still has the air and the big heater box on the pass side. None of that has been changed.
It's called custom fit by R&D Racing.
Old Jul 13, 2006 | 02:04 PM
  #22
1racerdude's Avatar
I am going to test it when it gets running. Shouldn't be much at all.
Thanks for the compliment.
Old Jul 13, 2006 | 06:27 PM
  #23
FASTFATBOY's Avatar
Here is a pic with it mocked it up in the car...
Y pipe Mocked up in the car
Floorboard....
Inside car
Enjoy
David
Old Jul 13, 2006 | 09:24 PM
  #24
96speed's Avatar
Thumbs up Re: Is this exhaust BIG enough? Big Mama inside
Did you guys modify the collectors "up?" I ran my Ypipe directly off of the headers (tried to get the Ypipe higher, but it wasn't happening by the time I was finished.
Hey, I can appreciate the work it takes to make Hedman headers work. Been there, done that. I chpped my #1 to get the power steering workin'. Ran out of $team on my project tho. You know the story on that, LR .
R&D Racing? (Old) Ross & David?
Ryan
Old Jul 13, 2006 | 09:38 PM
  #25
1racerdude's Avatar
Only on the drivers side as it was pointing down. Made it level with the car and fit things up.Had to mod the brace that it has to go by under the seat.
Headers were moded for steering and air/heater box clearance.
Ain't out of steam yet 'cause it ain't finished.
Ya got the OLD part right, but not TOO old.
Old Jul 14, 2006 | 09:19 AM
  #26
chy20k1's Avatar
damn talk about ground clearance. haha looks good
Old Jul 14, 2006 | 09:39 AM
  #27
EDS Z28's Avatar
Very nice!
I also used a flowmaster Y in my exhaust (3" to 2-2 1/2"), but I used it at the rear-end, with each side going to basically the same muffler you have, a straight thru magnaflow (4" dia x 14"L), so it looks like duals from the back. It sounds pretty good, actually wish it was a little quieter, it has a lot of bass. My midpipe is a single 3". The flp y-merge coming from the cats was modified to make it bigger.
Old Jul 14, 2006 | 10:03 AM
  #28
)2overt SS's Avatar
Wow, that looks awesome!
Besides a welder... what kind of tools did you need to do that job?
Old Jul 14, 2006 | 10:21 AM
  #29
T/A lt1's Avatar
Looks good guys. It will take quite a few tools and some good fab work to do something similar. I brought the all the parts: 3" x-pipe, mufflers, mandrel bends and pipe to a local muffler shop and the guys fab a true dual with x-pipe. I will have to take some pics for you guys. Later Clint
Old Jul 14, 2006 | 11:52 AM
  #30
FASTFATBOY's Avatar
Ryan
Ryan how much power did you make through your old setup? What kind of muffler was on it? Did it make any more power un capped?
