EVAP solenoid
EVAP solenoid
If you start your car and let it idle from cold to operating temp. does the EVAP solenoid energize anytime during that interval? Reason being, i did the tb coolant bypass, started the car and let it idle and warm up to check for leaks. While under the hood I could smell some gas fumes coming from the passenger side after the first few mins of start up. it faded away after that. If its not the EVAP solenoid, what would you check next?
jackpawt883
Sep 10, 2015 08:53 PM
350350
14
Aug 11, 2015 12:03 PM
