Evap Purge Solenoid Pluged ?
Old Mar 17, 2006 | 12:35 PM
ram air camaro's Avatar
i have a 94 camaro z28,
i noticed yesterday that my egr solenoid was pluged with little plastic crumbs so i sucked on the hose that comes from the evap canister and i nearly threw up when i ended up with a bunch of crap in my mouth.
my question is how do i fix it ? can i delete it ?
that could explain why there is always alot of air when i take off the gas cap kind of sound's like a nitrous purge just 2 times quiter
any help is apreciated, thank you
Old Mar 17, 2006 | 01:52 PM
Digital Designs's Avatar
Re: Evap Purge Solenoid Pluged ?
you can get the CCP program removed from PCM from a simple mail order tune.
Old Mar 17, 2006 | 02:42 PM
The EVAP system connects to the charcoal canister in the drivers rear fender. Your solenoid, and probably the line is plugged with carbon particles. You would need to replace the charcoal canister.
Your tank vent system isn't working. A plugged canister would explain part of it, but there is a pressure relief valve that should prevent too much pressure buildup. If replacing the canister doesn't solve the pressure problem, the relief valve might need to be replaced.
The system actually recovers and lets the engine burn gasoline vapor that would otherwise be vented to the rear of the car. If you delete the system, you need to make some provision for a tank vent - either a vented cap, or simply cutting the line to the canister and putting a filter sock over it. You'll probably notice an increase in fuel smell at the rear of your car.
Old Mar 17, 2006 | 03:08 PM
i think i will just fix it and not try to delete it, souds like more work.
so here is what your ( injuneer) suggesting for me to do
1. replace evap canister
2. replace evap purge solenoid , unless i could find a way to clean it
sounds pretty easy i think,
do you know if that could be cuasing my hisitation at 5-6k rpm ?
thanks on your input guys
MDZ28
11
Sep 24, 2015 09:15 AM
marlar98
Sep 19, 2015 07:53 AM
jackpawt883
Sep 10, 2015 08:53 PM
350350
14
Aug 11, 2015 12:03 PM
Alibi
Aug 1, 2015 07:50 PM
