Evap hose crack -Emissions?
Old Mar 23, 2007 | 02:30 PM
blaze309's Avatar
I found a crack in the hose that runs from the evap purge solenoid to the throttle body. The crack is at the 90 degree rubber elbow that connects to the throttle body and when i squeeze the elbow a black liquid came out (i think the hose is dirty and changed the color) anyways it smelled like gas. And i'm wondering if maybe gas is getting into the throttle body and causing me to have High Hc levels in emissions. I'm not sure how the evap's supposed to work but i dont think gas should come through that line?
Old Mar 23, 2007 | 04:46 PM
OBE1 95Z28's Avatar
The Evap system collects engine vapors (including gas vapors) to prevent them from entering the atmosphere by routing them to a charcoal canister (absorbing material). When the engine is running (specific run conditions, not all run conditions), the fumes are returned to the engine's intake track to be burned. Therefore it makes sense that this tube smells like gas.
Old Mar 24, 2007 | 01:20 PM
May also indicate that your charcoal canister is saturated with gas, and the vacuum is pulling liquid fuel into the EVAP system.
IndyZman
Oct 22, 2015 02:17 PM
MDZ28
11
Sep 24, 2015 09:15 AM
Fatdog2
Sep 16, 2015 11:04 PM
Daluchman1974
Sep 11, 2015 06:12 AM
scottcba1
Sep 8, 2015 09:52 AM
