Error Codes PO171 & PO174
Old Jul 22, 2004 | 10:31 AM
jerms1031's Avatar
Exclamation Error Codes PO171 & PO174
Someone please help me?!? I scanned my computer with a MAC Tools scanner and it read codes PO171 and PO174. My engine light intermittently goes off and on. At first, I thought it was an O2 sensor, but it looks like it may be something else. What does that mean what do I do to fix it? Thanks.
Old Jul 22, 2004 | 10:35 AM
944v8inDFW's Avatar
Re: Error Codes PO171 & PO174
http://shbox.com/1/Dtcs.htm good place to start!
Old Jul 22, 2004 | 10:42 AM
Your engine is 1) running so lean that the PCM can not correct the problems, using the maximum range of the long term fuel correction (+25%); or 2) False information is causing you PCM to assume the above.
Actually running lean:
-inadequate fuel pressure
-faulty MAF
-huge vacuum leaks
"False" lean:
-exhaust leaks before the O2 sensors
-excessive misfires
-faulty O2 sensors
Old Jul 23, 2004 | 11:26 PM
jerms1031's Avatar
Thanks, I appreciate the help...I'll try it and see what happens.
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
nbm_2001_z28
Jul 5, 2002 05:10 PM
tbyrne
Jul 2, 2002 05:37 PM
felo72
Jun 10, 2002 01:46 PM
