Equipment removal question
Old Aug 3, 2016 | 08:17 PM
vicki711's Avatar
I have a 95 z28 I removed the air pump and sensors as well as the evap sensor...do I need to keep the sensors plugged in even know I'm not using what they control?
Old Aug 3, 2016 | 09:27 PM
Re: Equipment removal question
What sensors? EVAP does not have a sensor, it has a solenoid. What is the reason for removal of these things? Trouble codes will follow for most items.
Old Aug 3, 2016 | 09:39 PM
vicki711's Avatar
Be everything involved with the evap sys and air pump
Old Aug 4, 2016 | 10:15 AM
The EVAP system recycles collected fuel vapor. Keeps the back end of the car from stinking of gasoline. Doesn't hurt performance in any way. Neither does the AIR system.
As Rob indicated, there are no "sensors" associated with either system, so it appears you deleted the systems without knowing the details of what you were doing or why???
DETROIT_AREA_00_SS
Aug 20, 2016 01:44 PM
4586
Jul 31, 2015 06:03 PM
97TA-WS6-Con
Sep 5, 2002 02:26 AM
ROCKN SS
Aug 11, 2002 07:35 PM
kraka
Mar 29, 2002 05:33 PM
