Engine Turn Off at Low RPM
Old Aug 15, 2005 | 12:06 PM
CamaroGuy22's Avatar
This is for a friend. Engine shuts off while coasting down hills or stopped idling. What could cause this? New plugs, wires, opti. Is the car idling to low? I think it is still idling at stock rpm.
His car idles at 700 rpm, my car idles at 1,100 rpm.
Old Aug 15, 2005 | 01:52 PM
MyShibbyZ28's Avatar
Re: Engine Turn Off at Low RPM
My car idles right around 500 and it's fine, doesn't bog down or nothing. maybe he has some tranny problems bogging it down, idk. That's a tough one.
Old Aug 15, 2005 | 03:27 PM
Black1995Z's Avatar
My car used to do this after heavy nitrous runs. It would die at stops and in neutral. My engine later died from low oil pressure. Make sure he has good pressure; it might be a sign.
Old Aug 15, 2005 | 04:24 PM
The IAC valve opens up to prevent stalling on closed throttle coast down. As long as the car is rolling (VSS not = to "0") the RPM should stay above the normal "idle speed". Maybe the IAC passages are plugged up or the IAC valve is dead.
Old Aug 15, 2005 | 04:38 PM
ZMAN Z28's Avatar
Wouldn't you throw a code for a bad IAC? Just asking, because mine died while pulling into a parking stall today. I had my IAC off during the rebuild to clean it. I used carb cleaner and a brush and didn't take apart the spring or plunger.
ZMAN
Old Aug 15, 2005 | 07:50 PM
Update: I think it is a fuel system problem. The car cuts off like it is running out of gas. The car died and didn't start for awhile. After adding dry gas to the tank it was able to be started up and driven home.
Is this a sign the fuel filter is clogged possibly?
Anything else I should check?
Old Aug 15, 2005 | 09:53 PM
There is no code for the IAC valve. It could be completely missing and not set a code in OBD-I. The PCM reading is simply what the PCM is commanding the valve to move to, there is no feedback as to whether the valve is actually doing what its told. You will eventually get a code for idle speed out of range in OBD-II, but not in OBD-I.
If you feel there is inadequate fuel, check the fuel pressure.
AlaskaZ28
Jan 1, 2015 12:30 PM
AlaskaZ28
Dec 16, 2014 07:24 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
