Engine Turn Off at Low RPM
This is for a friend. Engine shuts off while coasting down hills or stopped idling. What could cause this? New plugs, wires, opti. Is the car idling to low? I think it is still idling at stock rpm.
His car idles at 700 rpm, my car idles at 1,100 rpm.
Re: Engine Turn Off at Low RPM
My car used to do this after heavy nitrous runs. It would die at stops and in neutral. My engine later died from low oil pressure. Make sure he has good pressure; it might be a sign.
The IAC valve opens up to prevent stalling on closed throttle coast down. As long as the car is rolling (VSS not = to "0") the RPM should stay above the normal "idle speed". Maybe the IAC passages are plugged up or the IAC valve is dead.
Wouldn't you throw a code for a bad IAC? Just asking, because mine died while pulling into a parking stall today. I had my IAC off during the rebuild to clean it. I used carb cleaner and a brush and didn't take apart the spring or plunger.
ZMAN
ZMAN
Update: I think it is a fuel system problem. The car cuts off like it is running out of gas. The car died and didn't start for awhile. After adding dry gas to the tank it was able to be started up and driven home.
Is this a sign the fuel filter is clogged possibly?
Anything else I should check?
sleeperZ96BT
Jun 5, 2005 09:33 PM
