engine tear down.......
Old Jul 24, 2007 | 11:29 AM
  #16
thebufenator's Avatar
whats the best way to clean all the carbon off?
I tried WD-40, pb blaster, and seafoam with no effect......
Old Jul 24, 2007 | 10:53 PM
  #17
NovaTodd's Avatar
I used Castrol SuperClean and a scotchbrite pad - just wear rubber gloves
Old Aug 1, 2007 | 08:23 PM
  #18
quick question, the installed height that I see for the 1218 springs are 1.8in
I am alittle over, at about 1.85
I am assuming the 1.8 is the tallest, but 1.77-1.80 is fine......right?
Thats what I have seen around.......also, does it matter what shims I get?
Old Aug 2, 2007 | 07:22 PM
  #19
2nd_chances's Avatar
Only way to tell about the lifters is if your oil had metal in it, then the lifters do, if it doesn't the lifters aren't going too. If you spun a bearing the lifters might be junk so it's time to replace them.
bret[/QUOTE]
My 396 spun #4 main. Pieces of bearing material are laying in the lifter valley.
I was hoping to salvage the cam/lifters/tc/rods/heads, buy a new set of pistons and build a stock crank 355 with a fresh block. It would suck to loose another $300+ if I can't re-use a set of Morel lifters.
Can they be disassembled and cleaned?
Sergio
Jan 27, 2016 04:27 PM
dale3in98
Feb 14, 2015 12:18 PM
maybe2fast
Feb 5, 2015 05:14 AM
siguy
Nov 27, 2014 10:07 AM
