Engine swap need help with wiring.
Old Aug 23, 2010 | 12:22 AM
henryz28's Avatar
I am going to swap a motor and trans from a a4 f-body into a M6 f-body. I have the engine swap part down fine, my problem is I need to replace the wiring harness on my 1997 ta with the engine and trans wiring harness on my 1996 z28. Are there any write ups on this procedure or can some one help me out here?
Old Aug 23, 2010 | 08:10 AM
There should be virtually no difference in the 96-97 harnesses.
Old Aug 23, 2010 | 02:57 PM
henryz28's Avatar
Thats great. If I am swapping in a A4 motor/trans harness and pcm into a M6 is it just plug and play?
Thanks I was worried about this.
Old Aug 23, 2010 | 03:05 PM
1badeagle's Avatar
Im not positive since its been a while since i did my stand alone harness. But you will have extra wires if going to a a4. I beleive the reverse lockout switch and backup light switch will be there.
Old Aug 23, 2010 | 07:45 PM
What I read into your post was that you had both harnesses. There should be no problem using either one, but if you have only one harness, all of the transmission plugs may not be there.
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
rocketman051894
Jan 30, 2015 03:23 PM
cmdeshon
Jan 4, 2015 11:15 AM
cmdeshon
Dec 12, 2014 10:51 PM
Cam28_boy
Aug 6, 2002 08:40 AM
