Need help passing emissions
Old Aug 21, 2010 | 05:11 PM
84zed's Avatar
Had the car tested twice and it failed both times.It passes easily on co`s
and hc`s but was over on nox.The car is a 1995 a4 z28 with a cai and bbk headers and a high flow cat and a catback.The car is virtually unchanged from two years when it passed(close on nox but it did pass)I was talking to one
mechanic who said putting the stock 192 thermostat back would help and also
having the test done in drive instead of overdrive would help.The rpms were
only 1491 during the test.Are our engines more efficient at higher rpms.
HC ppm limit 55 reading 19
co% limit .31 reading .01
NO ppm limit 408 reading 753
Old Aug 21, 2010 | 05:43 PM
GreenDemon's Avatar
Either the EGR system is not working/plugged or that high flow cat isn't cutting it. Based on your CO/HC readings I would tend to think the cat is ok.
You can test the egr by pulling a vacuum on the egr valve at idle. The engine should run very rough (may stall). Usually egr systems will plug up w/ carbon and the egr valve may be sticking as well, which requires valve replacement and cleaning out the egr passages. If there's no change in idle quality then it's definitely not working at all.
Generally speaking an engine produces the most nox when it's hot and under load. So I doubt the thermostat will do much, but putting it in drive may ease things up a bit if it's allowed. Running the test as soon as the engine goes into closed loop (just warmed up) will keep nox lower as well, but will obviously push hc and co up.
Old Aug 22, 2010 | 06:38 PM
Read GreenDemons response carefully, he has covered it all......
Stock t'stat in an LT1 is 180*F. It is a different thermostat than the Gen 1 SBC uses. If your mechanic thinks 192* is stock, he probably doesn't realize that the LT1 uses a unique thermostat either.
And the mechanic's logic is backwards.... raising the coolant temp lowers HC and CO, and raises NOx. NOx is produced by high combustion chamber temperatures, and lean A/F ratio.
Old Aug 23, 2010 | 09:00 PM
84zed's Avatar
What about a 160 therm. and some octane booster.I will check the egr but it looks like one huge PITA to remove and clean.
Old Aug 23, 2010 | 09:41 PM
MikeGyver's Avatar
I'm betting its EGR related. Do the usual check for vacuum, exhaust, and post MAF sensor leaks too.
David Dempsey
Mar 12, 2016 12:42 AM
sleeperZ96BT
Sep 9, 2015 08:28 AM
Steve69SS396
Track Kill Stories
Aug 17, 2015 08:48 PM
sherwinZ28
11
Aug 15, 2015 05:38 PM
Cam's maro
Aug 11, 2015 07:45 AM
