Engine Swap
Old Jan 1, 2011 | 02:12 PM
gld77's Avatar
Engine Swap
I wrecked my 1997 z/28 Camaro beyond repair.I bought a1994 Z body I noticed that the wiring harness are different the 97s smaller.My question is whats the best way to do this swap leave the 94s wiring or change to the 97 wiring.My car was tuned and everything can i use the 97s ecm.I could use any help.
Old Jan 1, 2011 | 02:36 PM
94Camaro_Z_28's Avatar
Re: Engine Swap
I'd change the wiring to the 97. The Opti has a different harness in 94, as well as your 97 is OBDII and a 94 is OBD1
Old Jan 1, 2011 | 09:12 PM
#2's Avatar
Re: Engine Swap
try asking in the correct tech section. they're there for a reason.
Old Jan 1, 2011 | 09:38 PM
Re: Engine Swap
What do you mean by "the wiring harness are different the 97s smaller."? The harnesses are extrremely similar, with the 97 having several ADDITIONAL connections that the 94 would not have:
-crank position sensor
-EVAP vacuum detection switch
-after-cat O2 sensor on each side
Other than that, the connections are all virtually identiacal. You can run the 97 engine on the 94 harness and PCM, simply by pulling the short Opti harness off the 97 and replacing the short Opti harness on the 94. For the CKP, EVAP vacuum switch and after-cat O2 sensors, you would simply not hook them up. No effect on the engine or the way it runs. You will also have to replace the 97's 100kOhm knock sensor with a 4kOhm knock sensor from a 93-95.
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
rocketman051894
Jan 30, 2015 03:23 PM
cmdeshon
Jan 4, 2015 11:15 AM
cmdeshon
Dec 12, 2014 10:51 PM
Cam28_boy
Aug 6, 2002 08:40 AM
