Engine stumbles when fans kick on?
Old May 18, 2007 | 07:52 AM
Thor39's Avatar
When ever my fans kick on my engine stumbles and about dies. why is it doing this and how can i fix it?
thanks for the help
Old May 18, 2007 | 08:34 AM
CrazyLT1's Avatar
Does the check engine light come on at that same time?
Old May 18, 2007 | 09:40 AM
Thor39's Avatar
no it does not...
Old May 18, 2007 | 10:18 AM
Style's Avatar
Are the fans coming on at normal operation? Does it stumble at idle when you turn on the A/C and when coolant temp conditions are met? Are you using a manual fan switch? Is your PCM tuned?
Also, when did this problem start? Does it happen all of the time?
Old May 18, 2007 | 10:50 AM
speedfreakracing's Avatar
You've got a bad ground.
Old May 18, 2007 | 10:56 AM
Thor39's Avatar
The fans turn on at the right temp. I have not tryed to turn on the a/c its not hooked up. and my computer is not tuned for the hot cam yet..
If it is a ground how do i start to go about that?
Old May 18, 2007 | 11:03 AM
95ttoplt1's Avatar
A voltage drop test would be the best, I start with the ground that the fan and the PCM uses.
Old May 18, 2007 | 08:51 PM
Guest47904's Avatar
Guest
Check the voltage across the battery with the engine running. should be 14 or higher. Then turn on all the lights, rear defogger and the inside cabin fan. See that the voltage does not get below 12.6 volts.
Old May 18, 2007 | 09:25 PM
Your idle is probably not right, since you have not retuned for the Hot cam. This, coupled with the extra drag from the alternator when the fans kick on, may be causing your problem.
Old May 19, 2007 | 12:05 AM
AndyB's Avatar
Does the car run fine for the first few minutes after a cold start and then stumbles when the fans turn on?
linz
3rd Gen / L98 Engine Tech
Apr 7, 2015 11:49 AM
David Dorris
Jan 17, 2015 08:10 PM
njspder
Middle Atlantic
Jan 8, 2015 11:13 AM
IRABuss
Sep 7, 2011 09:08 PM
Jul 4, 2005 05:00 PM
