Engine Stand
Old Sep 8, 2018 | 03:11 PM
weedog's Avatar
Engine Stand
Where Can You Buy A Engine Stand That Will Work With The LT1 Engine Block. I Bought The 2 Ton Engine Stand At Harbor Fright And It Want Bolt To The Block Like It Should. And While I Was In There Was Another Guy Said He Had The Same Problem With The One He Bought.
Old Sep 8, 2018 | 03:27 PM
Chimera96's Avatar
Re: Engine Stand
I have the "harbor freight" engine stand and my LT1 bolts to it fine. Has several times.
The "ears" of the stand are adjustable
Old Sep 8, 2018 | 05:29 PM
Re: Engine Stand
It's basically the same as any SBC, so the stand should handle it without issue.
Old Sep 8, 2018 | 07:52 PM
weedog's Avatar
Re: Engine Stand
The one you have is it a 2 ton from harbor freight. the one I got is nothing like the display one on the floor mine is a lot larger. 3 of the ears line up just fine. The old motor stand I sold 5 or 6 years ago when I thought I would never build another motor I never had a problem with it on blocks. I turned 61 in may and have a bad back getting to old for this.Thanks
Old Sep 9, 2018 | 01:37 PM
Chimera96's Avatar
Re: Engine Stand
Well I have a few years on you. I have this stand. It holds 1k lbs
https://www.harborfreight.com/automo...and-69520.html
Old Sep 9, 2018 | 04:13 PM
Re: Engine Stand
Originally Posted by weedog
The one you have is it a 2 ton from harbor freight. the one I got is nothing like the display one on the floor mine is a lot larger. 3 of the ears line up just fine........
Don't think I've ever heard of a 2 ton engine stand. Do you possibly mean 2,000 lb.?
Old Sep 9, 2018 | 08:32 PM
GaryDoug's Avatar
Prominent Member
Re: Engine Stand
One of the reviewers reported that the one he had shipped to him did not look like or perform as well as the demo on the storeroom floor.
Old Sep 10, 2018 | 12:12 AM
95LT4Z28's Avatar
Re: Engine Stand
that stand should work just fine. just have the right positioning of the arms. with the block upside down align the arms in the straight slots with the bottom of the block. the arms in the slanted slots should be able to bolt up to the top of the block.
Old Sep 11, 2018 | 08:30 AM
weedog's Avatar
Re: Engine Stand
yes 2000 pounds sorry
30AnvZ28
Feb 3, 2008 05:22 PM
DOOM Master
Oct 24, 2005 10:28 PM
MJ_Z28
Feb 1, 2005 09:38 PM
EKO
Parts Wanted
Jan 4, 2005 11:17 PM
AP Engineering
Sep 11, 2004 11:33 AM
