Engine Stalls/Shuts Off After 10 mins Of Running!
Old Jul 17, 2011 | 07:47 AM
sickler's Avatar
ok iam looking to buy this 1993 camaro z28...the guy says it runs and drives but after 10 mins it stalls out...he thinks it could be the opti..any opinons?
thanks!
Old Jul 17, 2011 | 09:03 AM
MyFastTA's Avatar
Re: Engine Stalls/Shuts Off After 10 mins Of Running!
You need to find out what it is loosing when it stalls and if when it cools down it re starts or if it re starts right away. But it would be helpful to know if your losing fuel or spark when the vehicle stalls and dies and then we can go further from there. It is fairly common on any vehicle for ignition parts to fail when they get hot ex. coil/module but it is impossible telling what it is you have going on without more information.
Old Jul 17, 2011 | 09:22 AM
Very easy to scan the 93 for codes, using a paperclip.
Courtey of Shoebox.
http://shbox.com/1/dlc2.jpg
Code list:
http://shbox.com/1/Dtcs.htm
Old Jul 17, 2011 | 11:44 AM
sickler's Avatar
It will b hard to get all the info I need to diagnose it since its not my car lol...but he told me that wen it stalls just the engine shuts off power stays on...also he said sometimes it will start right up and sometimes he has to wait alittle for it to start
Old Jul 17, 2011 | 12:51 PM
mrmint69's Avatar
The real question is if he is giving the car away a lot cheaper because of the problem. It might be something so simple as the icm getting hot and you buy the car cheap and have an easy fix. You could also tell the seller the way to retrieve the codes and give them to us, to see what might be wrong.
Old Jul 17, 2011 | 05:40 PM
I understand it's not your car.... I read your first post.
He won't let you scan it for codes? Or he won't do it for you? Either way, I'd be suspicious.
Old Jul 18, 2011 | 05:43 AM
Guest47904's Avatar
Guest
Pass it by. 93's are stinkers any way. If you are dead set on getting an LT1 than find a 94 or 95. But find a scanner that works with them first. That will be the trick.
Old Jul 18, 2011 | 09:36 PM
cthomson21's Avatar
Does it have a cat? Mine did the same thing, and that's the reason I got it so cheap. It would crank fine, but after a few minutes you could look under the car and it was a distinct orange glow coming from the cat. Knocked the guts out, and it worked fine.
97z28k&N
Jan 9, 2015 04:58 AM
dirtybird81
10
Jan 6, 2015 09:31 PM
blac94Z
Dec 2, 2014 12:09 PM
supercharged94Z28
Feb 24, 2003 10:22 PM
