Engine stalling when put into gear
Old Aug 10, 2019 | 10:31 PM
Jameson Oeffler's Avatar
I just acquired a 95 z28, when I go to put the car into r or d the car stalls hard, currently pulling a code 83 an 84. I know code 83 is the torque converter solenoid, so I replaced it but still having the same issue. If I lift the back tires off the ground I can get it into gear an run but i have little to no penal response. Any help would be great!?
Old Aug 11, 2019 | 06:55 AM
JakeRobb's Avatar
Super Moderator
Re: Engine stalling when put into gear
According to Shoebox’s site (http://shbox.com/1/Dtcs.htm), the specific descriptions for those codes on your car are:
84: 3-2 Control Solenoid Circuit
85: Transmission TCC stuck on
TCC stuck on would definitely give the stalling issue you’re describing, but neither code explains no response from the pedal. It’s odd that you wouldn’t get another code for that.
Have you tested for fuel pressure?
Old Aug 11, 2019 | 09:31 AM
I just replaced the solenoid still having the same issue, an no I haven’t tested the fuel pressure weird thing is I Can rev the motor in p an n just fine but not in gear when I have the back tires up
Old Aug 11, 2019 | 11:48 AM
According to your first post, you replaced the TCC solenoid, because you had the wrong code description.
DTC 84 indicates "Automatic Transmission 3-2 Control Solenoid Circuit". That's right out of the factory service manual - free download here - courtesy of GaryDoug:
http://www.mediafire.com/?40mfgeoe4ctti
See page 6E3-A-152
DTC 85 is "Transmission TCC Stuck "On" ".
Old Aug 11, 2019 | 12:27 PM
So i replaced the wrong Solenoid?? is that what your saying?
Old Aug 11, 2019 | 06:14 PM
Not sure how to make this any clearer.
DTC 83 is for “TCC PWM Solenoid Circuit Fault”. Replace TCC solenoid, or look for wiring fault.
DTC 84 is for the “3-2 Control Solenoid Circuit”. Replace 3-2 solenoid, or look for wiring fault.
You can’t cure DTC 84 by replacing the TCC solenoid. Do you still have DTC 84?
On the other hand, DTC 85 is for the “TCC stuck ‘on’ “. Could be the TCC solenoid mechanically jammed, or circuit shorted to ground. But if the circuit was shorted, you would likely have DTC 83, which is not the code you said you had.
How did you “know”. DTC 84 “is for the torque converter solenoid”? Or was it a typo when you said DTC 84?
Pretty sure JakRobb was also pointing out the same inconsistency.
Old Aug 11, 2019 | 06:27 PM
Okay my bad i typed the wrong codes in, i had code 83 -Torque converter clutch solenoid circuit problem and 84 - Output Driver Module (odm) Fault. Skip Shift Circuit. That is what my code reader read when i scanned it.
Old Aug 11, 2019 | 08:45 PM
At this point, you might want to download the free factory service manual. That's not the correct description of DTC 84. Two of us have told you the correct description. Skip Shift only applies to manual trans.
Old Aug 11, 2019 | 09:00 PM
I am just going off what my scanner read and the description it gave me for each code, even off what you have gave me code 84 i do not think should lock up the transmission under a load on the back tires. And i have already replaced the tcc solenoid for code 83, Only other thing i can think of is the actual torque converter is locked up. But that is why i came here to get a second opinion, because i can not find anything online about this.
97trans
Jun 14, 2005 06:49 PM
Hawk350
Apr 20, 2005 10:47 PM
Mr_Superman
Jun 26, 2004 03:48 PM
SLeeper94Z
Mar 27, 2004 11:01 PM
ComputerNerd
Dec 21, 2003 07:50 PM
