help with code
Old Jun 13, 2005 | 07:55 PM
97trans's Avatar
help with code
the code is "Evaporative Emission Control System Malfunction". I know what the code is but i'm not to sure on how to check the system any help would be great. thank you
Old Jun 14, 2005 | 09:00 AM
Re: help with code
Generally, its best to throw in the actual code number... not all lists have the same description. I'm guessing you got P0433 = Evaporative Emissions (EVAP) purge solenoid control circuit. That would indicate either the EEC purge solenoid or the wiring to it is defective.
Courtesy of Shoebox:
http://shbox.com/1/evap_sol.jpg
His code list is also good to use, because it is LT1 specific.
http://shbox.com/1/Dtcs.htm
Old Jun 14, 2005 | 04:04 PM
97trans's Avatar
Re: help with code
the code # was P1441
Old Jun 14, 2005 | 06:20 PM
slopokrodrigez's Avatar
Re: help with code
That ones a B!@CH. Could be vacuum hoses to the purge solenoid routed wrong. Could be the vac lines going to the purge canister kinked or screwed up. Could be a switch, wiring, solenoid, the canister or the PCM itself.
You need a good manual, a scanner that can exercise circuits and a lot of patience.
Old Jun 14, 2005 | 06:40 PM
moparman's Avatar
Re: help with code
According to my manual, the possible causes are:
Rubber hoses cracked, cut, pierced, bent, or disconnected, as mentioned above
Plastic connector to EVAP canister purge solenoid cracked
Plugged hose from solenoid to canister or to throttle body
Terminals backed out, connectors or wiring damaged
EVAP canister purge solenoid fault or PCM defective
Slopokrodrigez covered it pretty good. Good luck.
Old Jun 14, 2005 | 06:49 PM
97trans's Avatar
Re: help with code
thanks guys, We just got the car for my gf. I was hoping it was gonna be an easy fix so I wouldn't have to drive an hour to drop it to them. They guarantee that it will pass emmissions, Ill send it to them
johnsocal
Aug 29, 2002 10:01 AM
Darth Xed
14
Aug 7, 2002 12:21 PM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
BigDarknFast
Jul 8, 2002 01:37 AM
