Engine revs on its own!!
Old Apr 14, 2007 | 09:32 PM
96redhotz's Avatar
I just installed a ported 52mm powder coated throttle body and intake manifold on my car(I didn't, my mechanic did) and as long as I don't touch the accelerator it idles fine. As soon as I hit the gas though, the RPM's start climbing on their own. I noticed that the coolant line in front points straight forward instead of angled to the left like my original. Could this be a TB for a third gen? Would that make a difference? Any advice would be greatly appreciated!
Old Apr 14, 2007 | 09:37 PM
'94 Bad A Z28's Avatar
Check the throttle linkage to see if it is getting stuck on anything.
Old Apr 14, 2007 | 09:42 PM
96redhotz's Avatar
It doesn't appear to be sticking. When I push the gas pedal it goes right back to position
Old Apr 14, 2007 | 09:43 PM
The pedal goes back to position or the throttle linkage? Even if the linkage gets stuck at WOT the pedal would go back to the normal position.
Old Apr 14, 2007 | 09:47 PM
It happened to my car the first time I sprayed it... went WOT on kit let off the gas a couple seconds later and the car kept going. Flipped the activation switch to shut the kit down and turned the key off to stop the car... got out popped the hood and the the mechanism that operates the butterflys on the TB (which is what I am refering to when I say linkage, sorry, not the cable) was stuck to my WOT switch.
Old Apr 14, 2007 | 09:48 PM
96redhotz's Avatar
Both. At least the linkage looks like its going back to position.
Old Apr 14, 2007 | 09:56 PM
Well, at the moment I am at a loss then, unless of course maybe there is a small leak somewhere along the way of the intake system before the TB and after the MAF. It may be possible that when you press the gas it sucks whatever small opening there may or may not be open enough to let in enough un-metered air the the car could be trying to adjust it's self for it. Dunno, just an idea. Check your intake elbow and silencer (if you still have one) for any leaks.
Old Apr 14, 2007 | 10:05 PM
96redhotz's Avatar
Will do! Thanks for the advice.
Old Apr 15, 2007 | 11:56 AM
onebad636's Avatar
Do you have traction control? My car just went full throttle by itself one day.
Old Apr 15, 2007 | 02:11 PM
96redhotz's Avatar
No, no traction control. I was wondering if it could have anything to do with the tps or the iac?
RUENUF
May 25, 2016 08:10 PM
Klypto
Mar 23, 2016 09:05 AM
RUENUF
Mar 13, 2016 03:39 PM
PCLZ28
Dec 24, 2015 05:19 PM
TheV6Bird
11
Jul 28, 2002 05:25 PM
