engine removal write ups
Old Oct 2, 2005 | 06:41 PM
Chevycobb's Avatar
A while ago I found a write up with pictures of someone that did it to their red firebird, but I can't seem to find it. The two I have are:
http://www.michiganspeed.com/enginepull/index.html
http://ken.lowrance.com/Projects/Hea...ineRemoval.htm
If anyone else knows the other one that would be great. He also had separate write ups for opti R&R, headers, etc...
Old Oct 2, 2005 | 07:03 PM
will62085's Avatar
Re: engine removal write ups
do you just need more info on doing this? im also in marietta and ive done this about 6 times, so ide be happy to come by and help out
Old Oct 2, 2005 | 07:23 PM
Chevycobb's Avatar
well I just want to be sure I have a good idea...this will be my first time doing it, so I guess i'm a little nervous about it. That and not exactly sure what specialty tools i'll need. I'm planning on starting this tomorrow.
Old Oct 2, 2005 | 07:34 PM
will62085's Avatar
well lets see...youll need jackstands, i use 4, two floorjacks or something else to roll the engine/tranny on, an engine hoist, other than that just basic hand tools
like i said, if you want ill come by and help ya out, i live off murdock rd. btw
Old Oct 3, 2005 | 02:11 PM
Chevycobb's Avatar
I may have to take you up on that...i need to figure out the wiring and the a/c and what to do with them
wish i could find that other write up...it seemed to be a little more detailed on these areas
Old Oct 3, 2005 | 05:29 PM
will62085's Avatar
well give me a call, ill come by and check it out, i know the wiring for this car like the back of my hand...lol 678 427 1255, if it doesnt ring, leave a message, my phone is messed up
Old Oct 3, 2005 | 06:56 PM
Chevycobb's Avatar
well the wiring wasn't as bad as I thought it would be...seemed to be only 4 connectors under the dash and the connectors to the computer...seems all I need to do now is figure the A/C out. I guess I have to discharge it somehow and figure out what lines to disconnect...wish there was a way I didn't have to do this....
Old Oct 3, 2005 | 07:04 PM
LiENUS's Avatar
If you can avoid it, please don't discharge the A/C system, find a friend with a collection system. If you can't avoid it, find a friend with a set of gauges who knows how to use em, hel'l be able to get better results discharging. If you cant find someone with gauges then goto autozone pick up a recharge kit, its a simple little adaptor that hooks one end to a can of refigerant and one end to the line, the line youl'l want to discharge is right next to the radiator cap if i remember correctly. just hook the charging hose up there then open the other end thats supposed to goto the can without a can attached. Be sure to do this in a well ventilated area, my father knew someone who died from refigerant inhalation. when you go to take the lines off they should detach right on the compressor.
Old Oct 3, 2005 | 07:52 PM
will62085's Avatar
you can just take the compressor off the motor and leave it in the car, then you dont have to disconnect anything...as far as that wiring...its much easier to just disconnect all the wires from the sensors and stuff and leave the computer in the car...you gotta take the harness of the motor anyway...may as well just leave it in the car
Old Oct 4, 2005 | 06:14 PM
Chevycobb's Avatar
well i didn't get to do too much to it today, except finding what I needed to get those fuel lines off was a PITA! I do have one question...on the strut towers, two of the bolts on the driver side are torx bolts(why the hell did they do that??) anyone know what size it is to get those off? biggest I have is T40 and it's too small..maybe t50???
Old Oct 4, 2005 | 06:59 PM
Dave89IROC's Avatar
its either t50 or t55 , and in responst to the guy up a few posts, it is much easier to pull the motor by just diconnecting the connectors under the dash, in total, there are only 6(93-94)or 7(95-97) connectors to the car from the harness
Old Oct 5, 2005 | 12:22 AM
will62085's Avatar
yeah but my point is since the harness has to come off the motor anyway once its out...it takes less time to just take it off while the motor is still in the car, it only takes 5 min. to take it off/put it back on anyway, and you dont have to unbolt the computer or dig under the dash finding wires, i dunno how that is easier...
also, for next time, just unbolt the fuel rails from the intake and leave them in the car as well...then you do not have to disconnect the fuel lines from it...and about that torx, i think its a t55, ive got it somewhere if you cannot find one...
Old Oct 5, 2005 | 04:21 AM
Honda Hunter's Avatar
Me and my friend were removing a 99 Cobra Engine and while messing with the lines it exploded in our face. Glad nothing bad happened.
Old Oct 6, 2005 | 09:21 PM
Chevycobb's Avatar
well the motor and trans are out....wish I had more time during the day to work on it. And just about everything is off the old motor that i'm going to reuse(water pump, alt, basically the accessories) the hard part now is getting the old off the k-member, and removing the tranny....not sure how i'm going to do that
DirtyDaveW
Dec 1, 2016 05:37 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
centric
Aug 15, 2002 09:04 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
dmaastr
9
Jul 1, 2002 02:22 PM
