Engine removal thru-bottom pics
Old Apr 16, 2005 | 11:19 AM
Slow ET's Avatar
About five hours of time including breaks. Did the all the disassemble myself and my brother helped with the lift part. All in all it was very fun and dirty I might do a little how-to write up on this
Old Apr 16, 2005 | 12:04 PM
matLT1's Avatar
Re: Engine removal thru-bottom pics
Through the top has my vote...lol...looks like a huge PIA
Old Apr 16, 2005 | 12:21 PM
Alvin@pcmforless.com's Avatar
Bravo,
Never seen anyone try it with a cherry picker.. usually they put 100 pieces of wood between the jack and car
Old Apr 16, 2005 | 01:18 PM
groundpoundinlt's Avatar
mine looks just like that right now...ill post some pics if i get a chance
Old Apr 16, 2005 | 02:01 PM
EviLZ28's Avatar
I also used a cherry picker to pick up the front of my T/A when I pulled the engine. Works out great. I put a dolly under the engine and after I raise the body, I just roll out the engine and trans. Takes me about 2 hours to unhook the components and get the engine out. I have done both and it is so much easier to work on the engine/Trans out of the car then trying to bolt up all the crap under the damn cowl in the car. Not to mention the cramps in the back and legs from being bent over the fender.
Old Apr 16, 2005 | 02:13 PM
neil350's Avatar
Tim did it with his blower 93 Z28, so mich easier, didnt have to take the blower off the car.
Old Apr 16, 2005 | 02:16 PM
EviLZ28's Avatar
I'll second that!!!!
Old Apr 16, 2005 | 02:39 PM
Pandamonkey's Avatar
Looks like a lot of work - although I guess not as much as taking it out the top mabye....
Old Apr 16, 2005 | 02:59 PM
hyperzone's Avatar
Do you have more pictures? I would be interested in reading anybody's write-up on something like this. Tips, pointers, and learning from mistakes (better when its not my mistakes) is what it's all about. I like the idea of pulling everything out the bottom alot.
Old Apr 16, 2005 | 04:42 PM
resurrectedz28's Avatar
I did it like that too, twice in the span of 1 week. It's very easy. Only thing diff I did was use a chain fall hooked to our garage (custom built garage) to lift the car so i could pull the engine straight out the front without moving a cherry picker or tryin to use a lot of wood on the jack. Took about a day the first time cuz i labled everything and was going real slow.
Old Apr 16, 2005 | 04:57 PM
brandboZ28's Avatar
Good work man. Handle that tranny with care.
Old Apr 16, 2005 | 05:15 PM
There are at least two write-ups out there already. I don't have links, but a search should find them.
I jacked the body off of mine and rolled out with the wheels on.
Old Apr 17, 2005 | 08:11 AM
Slow ET's Avatar
It was a fun experience. I did not have a list of things to removed, so it took a while to find what needed to be removed/disconnected. Ill post an LS1 edition in a few weeks
Old Apr 17, 2005 | 08:20 AM
Dave89IROC's Avatar
heres one
http://www.michiganspeed.com/enginepull/index.html
DirtyDaveW
Dec 1, 2016 05:37 PM
rjc1629
Jan 27, 2015 10:46 AM
alphaauto
Jan 23, 2015 07:42 AM
Queens94z28
Dec 20, 2014 09:11 PM
