Engine out the bottom question
Old Apr 12, 2010 | 03:55 PM
Queens94z28's Avatar
Hello,
My new motor is almost done and I want to install it from the bottom since its all assembled on the stand. Can I leave the wiring harness in the car and just plug everything in once I install the motor? I also left the AC compressor connected so I dont need to recharge it.
Everything is unplugged right now since I tore down the old motor to the shortblock which is still in the car.
I just done want to have to mess with taking the kick panel off and the pcm...etc. I think the only connections remaining are the ABS and Trans plugs...which I will get to next.
Old Apr 12, 2010 | 04:02 PM
monster81's Avatar
yes u can. just unplug all the connectors and lay the harness on the right fender, and dont forget to unplug the connector on the transmision if ur dropping it out the bottom.
Scottylt1
Jan 8, 2015 02:48 PM
cmdeshon
Dec 27, 2014 10:06 AM
Queens94z28
Dec 20, 2014 09:11 PM
Scottylt1
Dec 4, 2014 12:31 PM
formula218
Dec 2, 2014 04:27 PM
