Engine oil priming problem.
Old Jul 29, 2010 | 01:07 AM
GreasyB's Avatar
Ok so I am trying to prime the new engine. But I am not getting oil up to the cylinder heads. Maybe I am doing somthing wrong. If sombody could point me in the right direction that would be great.
Old Jul 29, 2010 | 05:31 AM
Guest47904's Avatar
Guest
Did you try rotating the other way?
How fast are you turning it?
How long are you waiting?
Old Jul 29, 2010 | 06:20 AM
bw_hunter's Avatar
How are you priming it...using a drill and a priming tool? If so:
1) don't expect oil to gush out of anywhere...the rockers could be lined up just right with the pushrods that you won't see much oil.
2) do you register pressure on the dash gauge? Even if using a priming tool, you can use the dash gauge by simply turning the ignition on without starting the engine.
3) Did you replace the pushrods and, if so, did you clean them before installation? Sometimes they are full of machining gunk...it's always a good idea to wash them first.
Good luck....
Old Jul 30, 2010 | 12:43 PM
GreasyB's Avatar
Well my first try oil came gushing out of where the sending unit is. Cause well.. I didnt think to put it on. So does that mean its all ok then?
Scottylt1
Jan 8, 2015 02:48 PM
NorthPoleDev
Dec 31, 2014 03:20 PM
Scottylt1
Dec 4, 2014 12:31 PM
guionM
69
Nov 30, 2006 02:01 PM
Jul 4, 2005 05:00 PM
