Engine Light?
You need to provide info about your car - year, model, engine, tranny and any major mods. That's what the "Signature" feature is for. Might want to add one.
For example... is your car OBD-I or OBD-II? Is it a 93, where you can flash the codes on the SES light by shorting the pins with a paper clip? Is it a 95, where things get complicated by the OBD-I PCM, coupled with a 16-pin OBD-II style ALDL connector. If its OBD-II, does the SES light flash, indicating a misifre, or is it steady.
If the SES light comes on, the code is stored. Its going to be there if scanned correctly.
It could be the opti, it might not be the opti. The '95 has the OBDII ALDL port, but it is OBDI. Confuses a lot of people, including experienced mechanics. You really need to find someone who has the proper scan tool and cable to perform a scan on it.
Or use an OBD-I scanner with a 12-pin connector, and jumper it to the 95's 16-pin connector as shown on Shoebox's site:
http://shbox.com/1/xraycable.jpg
Jan 5, 2015 07:14 PM
Jul 4, 2005 05:00 PM
