Engine Light?
Old Sep 19, 2009 | 11:28 AM
berakahs's Avatar
Engine Light?
i get a little misfire, then the light comes on.. then goes off... then back on. ne suggestions as to what it might be?
Old Sep 19, 2009 | 11:52 AM
Have it scanned, so you don't have to guess. That's the purpose of the light.
Old Sep 19, 2009 | 12:24 PM
berakahs's Avatar
i know.. already tried.. no codes are given...
Old Sep 19, 2009 | 01:05 PM
RamAir95TA's Avatar
The PCM stores any codes that are set. They're in there. What are you using to scan?
Old Sep 19, 2009 | 01:06 PM
berakahs's Avatar
a decent code reader...
Old Sep 19, 2009 | 01:08 PM
RamAir95TA's Avatar
You could be a little more informative with your answers so that we can help you a bit better.
Old Sep 19, 2009 | 01:12 PM
brianswimmer23's Avatar
yea the next itme it comes on try and get it scanned or go to someone that has a very good code reader not just the 100 dollar one.
Old Sep 19, 2009 | 03:06 PM
Yep, not much info to go on. We don't even know what he is driving.
Old Sep 19, 2009 | 03:36 PM
You need to provide info about your car - year, model, engine, tranny and any major mods. That's what the "Signature" feature is for. Might want to add one.
For example... is your car OBD-I or OBD-II? Is it a 93, where you can flash the codes on the SES light by shorting the pins with a paper clip? Is it a 95, where things get complicated by the OBD-I PCM, coupled with a 16-pin OBD-II style ALDL connector. If its OBD-II, does the SES light flash, indicating a misifre, or is it steady.
If the SES light comes on, the code is stored. Its going to be there if scanned correctly.
Old Sep 19, 2009 | 09:15 PM
berakahs's Avatar
1995 camaro z28 automatic... all stock, except flowmaster exhaust, and shift kit..... ive gotten word it could be my opti spark??
Old Sep 20, 2009 | 09:15 AM
moparman's Avatar
It could be the opti, it might not be the opti. The '95 has the OBDII ALDL port, but it is OBDI. Confuses a lot of people, including experienced mechanics. You really need to find someone who has the proper scan tool and cable to perform a scan on it.
Old Sep 20, 2009 | 09:44 AM
Or use an OBD-I scanner with a 12-pin connector, and jumper it to the 95's 16-pin connector as shown on Shoebox's site:
http://shbox.com/1/xraycable.jpg
David Dorris
Jan 17, 2015 08:10 PM
bfmv13trivium
Jan 14, 2015 09:57 AM
dirtybird81
10
Jan 6, 2015 09:31 PM
Jan 5, 2015 07:14 PM
Jul 4, 2005 05:00 PM
