Engine info?
Old Feb 15, 2008 | 06:05 PM
Austin_78@msn.com's Avatar
Engine info?
does anyone know if there is like a site or something where i can type in my vin and it will tell me the specifications of my engine?
Old Feb 15, 2008 | 06:07 PM
The Engineer's Avatar
Your local Chevy dealer can run and print a complete build-list for your car using the VIN.
WD
Old Feb 15, 2008 | 06:22 PM
do you know by any chance what that will run?
Old Feb 15, 2008 | 06:31 PM
Green96Z's Avatar
What are you hoping to find out of the vin? The engine code is the 8th digit, and all it will tell you is what engine it came with stock. S is the 3.4L, K is 3.8L, and P is 5.7L. If you are looking for specifics, the RPO codes will tell you.
Old Feb 15, 2008 | 06:35 PM
2000GTP's Avatar
What kind of engine specs are you looking to find,ie: power, fluids, torque?
Old Feb 15, 2008 | 06:41 PM
yeah basiclly the power, torque...im pretty sure i know them but i just wanted to know all the options and stuff the the car has...from interior to engine specs.
Old Feb 15, 2008 | 06:42 PM
what are these?
Old Feb 15, 2008 | 06:57 PM
Every option on your car is identified by a 3-character Regular Production Option code. You will find a build tag in your glove box, console or on the end of the driver's door that lists all the "options". There are websites you can go to to decode the RPO codes.
http://www.chevy-camaro.com/chevy-ca....asp?year=1993
http://www.marshu.com/ws6-resources-...nual-parts.php
Your VIN isn't going to tell you much of anything. You have a Z28, so you have the 275HP/325 lb-ft rated 350 cubic inch LT1 engine. Its the only engine installed in the 93 Z28's.
Check out this website:
http://www.ws6.com/faq/
Old Feb 15, 2008 | 06:58 PM
2000GTP's Avatar
what are these?
They are the alpha-numeric codes found in the glovebox or door jamb.
Old Feb 15, 2008 | 07:42 PM
thanks guys
Old Feb 16, 2008 | 08:25 AM
indirocz28's Avatar
Here- i found a lot of good info on this site
edman
Jan 25, 2015 02:41 PM
Not Dave
Dec 11, 2014 06:32 PM
bernie1951
Dec 10, 2014 10:03 AM
Nostang 96z
Sep 15, 2002 10:15 PM
