engine doesn't want to find idle
Old Oct 8, 2007 | 10:16 PM
afr lt1's Avatar
So I have been messing with the car trying to find out why the door locks dont work and I dis-connected the battery overnight. I put it back together and took the maro out tonight. Right away it didn't want to idle nicely. It would find idle here and there for a little bit. It was dropping to around 550. I haven't been in the engine bay moving anything either.
- I did stop and check for arcing (sp?) at the wires. I have a tiny spot that appears to be the boot on one wire. Well, I figured it wasn't this because I have burned up wires before and I dont think the idle jumped around then. I think it may be something else.
Old Oct 8, 2007 | 11:16 PM
AZ2ENVY's Avatar
What are your door locks doing ? Keep in mind the are a multiplexed
system so they are a pain to troubleshoot .
Old Oct 9, 2007 | 08:27 AM
afr lt1's Avatar
AZ2ENVY,
THe switches dont work AT ALL. My key fob will unlock the driver door. I have power to the switches and have applied power to the actuators and they work both ways. The switches also work when tested. Now I am about to test the Receiver in the pass. kick panel. I have read you can jump a couple of wires to test if the receiver is bad.
Old Oct 9, 2007 | 02:46 PM
mrmint69's Avatar
I car needs to relearn a few things after you disconnect the battery. It will adjust and go back to normal.
Old Oct 9, 2007 | 04:30 PM
Dave89IROC's Avatar
agreed, let it idle for ~10 minutes or so, and should be back to normal
Old Oct 9, 2007 | 05:33 PM
Shoebox also has an IAC relearn procedure on his website:
http://shbox.com/1/4th_gen_tech2.html#iac_reset
Old Oct 9, 2007 | 06:20 PM
afr lt1's Avatar
you are all correct, it has fixed itself. THanks!
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Gtpguy
Jan 26, 2015 04:50 PM
Alex Barnes
Jan 24, 2015 10:21 PM
A's 91 Z28
Jan 11, 2015 10:58 AM
jayblev95
Dec 1, 2014 06:55 AM
