new o2s now it acting up?
Old Oct 9, 2007 | 01:57 AM
sonia93's Avatar
I replaced my o2s saturday and ever since then my car is acting up it is surging while driving and when i push the gas it kinda boggs down what could this be?its almost like i got bad fuel....
Old Oct 9, 2007 | 02:52 AM
Zeueses 97 RamAir's Avatar
Explain
Was the car or what was the car doing before.
Old Oct 9, 2007 | 12:22 PM
Kevin Blown 95 TA's Avatar
Try disconnecting the battery to reset the PCM. Maybe it is tuned to your old sensors, and if they weren't working very well, those adjustments aren't right for your new sensors. Wouldn't hurt to start with a clean slate and see where the adjustments go - maybe it will help. Also see is anyone can scan it or log it for you.
Old Oct 9, 2007 | 12:24 PM
sonia93's Avatar
it was running fine i changed them cause i was told when you put headers on it burns them out plus my check engine light was coming on after i installed the headers so i assumed they were bad and it seems like as soon as i replaced them with the new ones it started running bad.
Old Oct 9, 2007 | 12:26 PM
sonia93's Avatar
I disconnected the battery right after i changed them maybe I'll try it again.
Old Oct 9, 2007 | 12:56 PM
That sucks - see if you can get a buddy to scan it for you and see what's wrong in there. Also make sure the wires aren't burned.
Old Oct 9, 2007 | 01:02 PM
If your SES light came on, did you try flashing the codes on the SES light to see why it came on? Your 93 is the only year LT1 you can flash the codes by jumping the pins in the ALDL connector. Generally a good idea to check the codes before you spend money on replacement parts.
http://shbox.com/1/dlc2.jpg
Old Oct 9, 2007 | 06:21 PM
sonia93's Avatar
what about bosch i was just told they didnt do well with our cars and thats what I put in it.....
Old Oct 9, 2007 | 06:35 PM
Well let's try a different approach - you just did headers - do you have a bunch of exhaust leaks? and are they maybe giving you a problem with a false lean signal to the O2 sensors making your car run rich?
Old Oct 9, 2007 | 06:47 PM
camarozz95's Avatar
did you use o2 extensions? or did you try to extend them yourself by stripping and crimping wire to extend them?
Old Oct 9, 2007 | 06:58 PM
moroso99's Avatar
did you do long tube headers, did you remove the cat that could be why the ses light is on.
Old Oct 9, 2007 | 07:06 PM
camarozz95's Avatar
No its a 93 Won't trip a ses light no post cat o2 sensors...
Old Oct 9, 2007 | 07:11 PM
moroso99's Avatar
ok, just throwing out a suggestion. something else to cross off the list of possible things that are causing the problem.
93 RedBird
Nov 15, 2015 08:24 AM
jayblev95
Sep 26, 2015 09:44 PM
98-LS1Z28
Sep 8, 2015 03:12 PM
CARiD
Sep 7, 2015 08:21 AM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
